Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 04-07-2010, 11:07 PM   #1
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Default perrin big maf scaling??
im about to purchase a perrin big maf intake and was wondering if anyone had the maf scaling for it?
bswilmington is offline   Reply With Quote
Old 04-08-2010, 11:21 AM   #2
bswilmington
Member#: 217563
Ttt..
Old 04-08-2010, 01:28 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
Default Re: perrin big maf scaling??
77mm (new intake) / 65mm (stock intake) = x
take x and multiply it to stock maf scaling, that should give you a base, then ho from there
Nuke209 is offline   Reply With Quote
Old 04-08-2010, 05:09 PM   #4
bswilmington
Member#: 217563
nice formula and makes sense thanks
ill do this unless someone already has them and is willing to share
Old 04-14-2010, 04:32 AM   #5
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
nope! don't use this! you need to use the SQUARES of each value. so it would be:
(77mm X 77mm) / (65mm X 65mm) = X
then (X) Multiplied by the stock MAF table. and you'll still probably need to scale it, but this might get you in the ballpark. good luck!
lil'redwagon is offline   Reply With Quote
Old 04-14-2010, 10:15 AM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The MAF scaling follows the cross sectional area of the tube, NOT the diameter. The cross sectional area is proportional to the square of the radius (or the square of the diameter, doesn't really matter), as lil'redwagon pointed out.
Old 04-14-2010, 11:49 AM   #7
bswilmington
Member#: 217563
so i use the formula 77squared/65squared = x
do i multiply x to the voltage or g/s?
im guessing the g/s since flow is increased and voltage of sensor should stay the same
Old 04-14-2010, 11:57 AM   #8
Member#: 51961
2005 STi
2012 WRX
Right, g/s
Old 04-14-2010, 01:27 PM   #9
bswilmington
Member#: 217563
thank you guys
Old 05-21-2010, 03:10 PM   #10
bswilmington
Member#: 217563
quick question for someone with good knowledge on intake tuning
1) should i raise the maf limit maximun over 300 with big maf?.
2) should i raise engne load limit over 4.0?
neither of these will probaly matter now since i still have vf39 but i should be on 20g by end of year or so.
anything else you guys could think of would be helpful. also i lowered my timing and added fuel to be safe on 1st tune.
Old 05-21-2010, 08:22 PM   #11
Member#: 51961
2005 STi
2012 WRX
You might as well do those anyway, it won't hurt anything
Old 05-21-2010, 09:15 PM   #12
bswilmington
Member#: 217563
what is your suggestion to how much
maf limit 400?? maybe more
load limit?? any ideas?
i just put it on couple hours ago so ive just wrote base tune right now and am scaling maf at this point.
Old 05-25-2010, 08:15 AM   #13
autox
Member#: 132013
2004 STi
I just ordered one, could you post the scaling when you are don tuning?
autox is offline   Reply With Quote
Old 05-25-2010, 05:22 PM   #14
bswilmington
Member#: 217563
yeah i can give them to you
ill have to send them to you later tonight when i get home from work
use it at your own risk cause i dont know your car but my correction is very close
below 40 g/s and im still tweaking above 40 g/s but it should be damn close.
my a is around -4% b-d are less than 2%
i dont know how close your af learning are but it may upset your tune if they are very far off
also it is installed with gimmick under manifold intake and i dont know if that will throw you off any
Old 05-25-2010, 07:34 PM   #15
bswilmington
Member#: 217563
autox do you have a wideband and have you ever done maf scaling?
i started with scale on top and then went to scale on bottom
started with
started with
maf volts maf g/s
0.9375 1.7239
0.9766 1.99047
1.0156 2.2851
1.0547 2.60779
1.09375 2.95854
1.1328 3.33735
1.1719 3.77228
1.2109 4.26333
1.25 4.76841
1.28906 5.31558
1.32812 5.91887
1.36719 6.63619
1.42625 7.32366
1.5044 8.76875
1.5825 10.3962
1.66062 12.164
1.73878 14.1282
1.7969 16.2888
1.875 18.6599
1.9531 21.2274
2.03125 24.2017
2.10938 27.611
2.1875 31.3991
2.26562 35.6362
2.34375 40.3643
2.42188 45.4011
2.5391 53.6227
2.65625 62.8965
2.7734 73.1384
2.8906 84.0397
3.0078 95.7968
3.125 108.508
3.2422 122.3
3.3594 137.27
3.4766 153.53
3.59375 171.124
3.7109 189.994
3.8281 210.576
3.9453 233.094
4.0625 258.447
4.1797 285.426
4.2969 313.065
4.4141 341.378
4.4922 360.711
4.5703 381.77
4.6094 392.924
4.6484 404.317
4.6875 415.947
4.7266 427.424
4.7656 439.251
4.8047 451.303
4.8438 463.593
4.8828 476.108
4.9219 488.875
then went with
final
maf volts maf g/s
0.9375 1.7239
0.9766 1.99047
1.0156 2.2851
1.0547 2.60779
1.09375 2.95854
1.1328 3.33735
1.1719 3.77228
1.2109 4.26333
1.25 4.76841
1.28906 5.31558
1.32812 5.91887
1.36719 6.63619
1.42625 7.32366
1.5044 8.76875
1.5825 10.3962
1.66062 12.164
1.73878 14.1282
1.7969 16.2888
1.875 18.6599
1.9531 21.2274
2.03125 24.2017
2.10938 27.611
2.1875 31.3991
2.26562 35.6362
2.34375 40.3643
2.42188 45.4011
2.5391 48.658
2.65625 54.81
2.7734 64.026
2.8906 75.636
3.0078 86.22
3.125 99.459
3.2422 113.67
3.3594 127.143
3.4766 145.377
3.59375 153.108
3.7109 165.591
3.8281 184.122
3.9453 205.281
4.0625 232.605
4.1797 256.887
4.2969 281.763
4.4141 307.242
4.4922 324.639
4.5703 343.593
4.6094 353.628
4.6484 363.888
4.6875 374.355
4.7266 384.678
4.7656 395.325
4.8047 406.17
4.8438 417.231
4.8828 428.499
4.9219 439.992
here is screen shot of learning view
Code:
CAL ID:A2ZJE11J
Description: 06 USDM Impreza STi MT
ECU ID:4312594006
IAM    1.0000
A/F Learning #1:
0 - <5.60    5.60 - <10.00    10.00 - <40.00    40.00+
-3.70        -3.30            -0.90             -0.50
FLKC Table      0 - <0.90    0.90 - <1.20    1.20 - <1.50    1.50 - <1.90    1.90+
0 - <2400       0.00         0.00            0.00            0.00            0.00
2400 - <3000    0.00         0.00            0.00            0.00            0.00
3000 - <3600    0.00         0.00            0.00            0.00            0.00
3600 - <4200    0.00         0.00            0.00            0.00            0.00
4200 - <5000    0.00         0.00            0.00            0.00            0.00
5000 - <5800    0.00         0.00            0.00            0.00            0.00
5800+           0.00         0.00            0.00            0.00            0.00
Old 05-25-2010, 09:57 PM   #16
Nuke209
Member#: 108089
2003 WRX
NF Performance
Did you tune that with the stock injectors or bigger?
if so, which injectors
Old 05-26-2010, 12:56 AM   #17
bswilmington
Member#: 217563
stock injectors but i do have size set to 513
another thing is its tuned with meth so top end fuel may be off some if somebody else uses it. i would only use this scaling if you have a wideband to make sure wot fueling is correct
Old 05-27-2010, 02:12 PM   #18
autox
Member#: 132013
2004 STi
Thank for the info, I have a wideband and will add fuel, take away timing. I just wanted a starting point.
Old 05-27-2010, 02:15 PM   #19
bswilmington
Member#: 217563
thats good to hear
the 1st maf scaling was a little rich to me, around 10.5:1 but i think my meth was on, so that maybe closer to what you need.
i got the second one by multipling everything above 40 g/s by 90% which made it almost dead on for me.
Old 09-10-2012, 03:41 PM   #20
1subie08
Member#: 323847
2008 Subaru wrx
i know this is an old thread but i have a perrin cai and im going to get it tuned in a day or 2. but what we need to save time and to help out is cai maf scaling's. i have looked but have not seen anything online or on this forum. if anyone has something for an 08+ wrx that would help a tone.
this is what i have
08 wrx
perrin cai
3" cat less turbo back
1.5 tune currently
stock td04 turbo
stock tmic
any help would be great.
thanks
1subie08 is offline   Reply With Quote
Anyone have the Perrin Big Maf "start from" Scaling for a WRX or Multipler? Wrx_Fan_0717 Open Source Reflashes 20 09-14-2009 03:10 AM
3in custom cai piping with perrin big maf or perrin blow thru with big maf Stiguy34685 AccessPort 5 01-29-2009 09:57 PM
perrin big maf- lightly used perrin standard size maf filter sti charles Engine/Power/Exhaust 8 09-01-2008 09:20 AM
Anyone have the maf scaling values for an Perrin Big MAF. Stock WRX injectors NITROS Open Source Reflashes 1 02-05-2008 06:57 PM
Are Legacy Gt Perrin Big MAF Intakes the same as STI BIg MAF??help BlackSTI2006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-20-2007 01:05 PM
