Old 09-01-2012, 10:45 PM   #1
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Default EJ22T - Should this hole be threaded?
I was tearing an ej22t motor down to the short block and noticed that there was a weird brass plug with RTV sealant around it plugging a hole right behind the EJ22 casting mark. I pulled it out. My question is, what is this hole for and should it be threaded or smooth? I'm wondering if a prior owner stripped it out. Here is a pic:
Soarer is offline   Reply With Quote
Old 09-01-2012, 11:20 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
No, its a breather port, there's supposed to be a 90 degree fitting there that's part of the crank case breather system
sense of nature is offline   Reply With Quote
Old 09-02-2012, 02:23 AM   #3
RallyColtTurbo
Member#: 16819
Many folks who use the EJ22T shortblock as the base for non-Legacy builds plug the hole, as you found.
It isn't part of the main breather system. It is only connected to the rocker covers on each side - sort of an equalization system. The main PCV breather lines go to a second set of ports on each head.
RallyColtTurbo is offline   Reply With Quote
