Old 09-03-2012, 10:57 AM   #1
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Default Late EJ20G Starter, stock RS trans. Help!
So my motor is in the car now, just ran into my first problem. Only 4 of the bolt holes will work for the starter so far. Do I need to tap the trans or is 4 enough?
I'm sure someone has run into this problem, but I haven't found one thread on it. Thanks in advance for the help!
GGSimpreza is offline   Reply With Quote
Old 09-03-2012, 11:38 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
i have done it two ways.
first time, i put a 6sp behind a 20G i tapped out the lower hole and put a larger bolt in it.
second time, WRX 5sp behind a EG33 i just ran the top bolt, i still haven't installed the lower bolt. still working fine.
i have also herd of people countersinking a bolt in from the front of the trans, so that a "stud" sticks out for the lower nut. like it was on the 20G.
-=Suberdave=-
suberdave is offline   Reply With Quote
