Old 01-19-2013, 01:01 AM   #26
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
actually if I do it right I will just have to take off the wheels.
here are the dimensions as I stated above:
from the left to right rail its 35.375
from the front of the rail to the fire wall it is 24.5 inches
jjppmm29 is offline   Reply With Quote
Old 01-20-2013, 12:13 PM   #27
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Seems like you could make this a lot easier on yourself by using a USDM single turbo swap. Heck it would be even better if you could find an ej22t since those are a little more compact and simple.
geronimo81 is offline   Reply With Quote
Old 01-23-2013, 03:46 AM   #28
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
I cant fit anything over a 2L into the metro It ends up being to wide.
Old 01-24-2013, 04:34 PM   #29
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
2.0 2.2 2.5 are all the same width.
Z0rr0 is online now   Reply With Quote
Old 01-24-2013, 05:37 PM   #30
Paidfor
Member#: 267815
Be in awe
dont hate .)
Hell............didnt Perrin say that even the H6 is the same width? Just about a inch longer i think.
Paidfor is offline   Reply With Quote
Old 01-25-2013, 03:39 AM   #31
Dori Ninja
Member#: 73974
04 RSTi
Yeah width will be the same...the 3.3 is a 2.2 and a half...literally lol everything inside is same as the 2.2
Dori Ninja is offline   Reply With Quote
Old 01-25-2013, 08:56 AM   #32
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
from what I have seen and heard the difference between a 2.0 and a 2.5 is about 4-6" in width and 3-5" in length witch puts the 2.2 and 2.5 beyond the size of my engine bay.... I might be able to run a 2.2/2.5 without a turbo setup but the clearance from my front cv linkage and radiator wont allow for it unless I run RWD so a 2.0 is the most I can run for what I want from her
Old 01-25-2013, 01:47 PM   #33
AKGC8
Member#: 1305
2000 Impreza
The SOHC EJ22 from the Legacy turbo is actually narrower. Width is 28.5" according to this site: http://www.sdsefi.com/air11.html
AKGC8 is offline   Reply With Quote
Old 03-14-2013, 12:42 PM   #34
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
eby you are right the SOHC is slightly smaller but why go with a little SOHC when i already have the nice beefy DOHC besides not many(if any) of the SOHC motors stack up to the DOHC models
Old 07-21-2013, 01:45 AM   #35
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
Sorry it has been so long since Ive posted... I had to fix my car situation so i have something to drive while I work on my car.
here are some pictures to wet your appetite
at this point I have already taken out the carpet and all but the driver seat
Some Before Pictures
I needed some parts so I went to a salvage but they didnt have what I was looking for... but thankfully they had some metros so I took a hatch and bumper from a 97 geo I think the bumper looks better... though still not exactly what I want
The original bumper has a lot of damage to it... faded discolored with a huge dent on the driver side from something I know not what. damage to the license plate clips and one of the fender support screw stand offs are destroyed. both the cars mine and the doner had destroyed fender brackets
Old 07-21-2013, 01:47 AM   #36
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
It was hell trying to fit that hatch in the back of my metro
Sorry no before pictures on the hatch... but it is basically the exact same
I also Installed a Spoiler if you had not noticed sorry no pictures. It was a pain to install and is still not perfect. if you dont know how to install a spoiler, look online, but for a short explanation, I assembled the spoiler off the car and took some masking tape across the feet, took off the feet leaving it attached to the masking tape and used that as a template. I failed the first time witched is why I needed a new hatch.
It took me two weekends to remove the dash all the screws are buried behind so it took me a wile to sniff them out and remove them.
after getting the dash off the only problem i had was with the steering linkage and the pedal box
Upon taking all the plastic off I found alot of Cancer over the wheel wells witch will have to be taken care of during the fabrication part of this build
so that leaves where i am at this point witch is pulling the engine witch will be hard to say the least without a engine hoist... i am going to have to drop it
on a side note I am contemplating Twincharging/Compound Charging the (what i have found out on closer inspection)EJ20R... I wonder if anyone has any opinions and or information on this
Also what is the most boost that has been ran on a EJ20R?
Old 08-07-2013, 01:22 PM   #37
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
Chassis is striped finally
Ive noticed rust cracks in the control arm supports... good thing their coming out of there
as well steering port and mounts have to come out
new fuel&brake lines will be needed
good news though, the frame on the whole is in good condition...
no buckling, bends, or bondo... just a little bit of rust in some of the surface metal
Old 08-08-2013, 08:07 PM   #38
dammitmitchell
Member#: 364057
two guys and a 2x4 can pull an engine out of a metro.
also anyting is possible. how about a twin engine talon?
http://www.turbomirage.com/shootout_..._dsm/hatch.JPG
dammitmitchell is offline   Reply With Quote
