Old 09-04-2012, 09:33 PM   #1
jaredperry
Member#: 170928
'07 STi / '02 WRX
So Cali FL4T F4 #36
Default Deciphering spun engine bearings
I was in search of a means to decipher a set of spun engine bearings and I came across this interesting webpage illustrating different ways bearings are destroyed.
http://catalog.mahleclevite.com/bearing/
Does anyone else have any other means to interpret or track down the cause of bearing failure?
jaredperry is offline   Reply With Quote
Old 09-04-2012, 10:33 PM   #2
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
I think that would be as in depth as it could possibly get. Thats a pretty good resource.
Purpose_Built is offline   Reply With Quote
Old 09-04-2012, 10:38 PM   #3
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
thats really cool!
Usually a "spun" bearing is just that. It actually bent the tabs and spun. there are causes for this that I do not know but from that link it does shows causes of bearing failures
There are other ways to interpret a cause. like if all the other bearings were ok you would know that maybe that rod/cylinder had a issue. I would than check the corresponding components and see what happened.
Bearing failures suck, they always suck but there could be a million things that can go wrong. Usually the bearings distroyed before you have a chance to look at it anyways.
