Old 09-02-2012, 04:00 PM   #1
ttemarantz
Member#: 330344
2005 Wrx
Default Does anyone have any idea what this is from?
I was driving the other day and this fell from in the footwell behind the steering wheel. I've looked already and theres nothing that i could find that's missing a plug. Does anyone have any idea what this could be from?
ttemarantz is offline   Reply With Quote
Old 09-02-2012, 04:02 PM   #2
ttemarantz
Member#: 330344
2005 Wrx
The pictures didn't upload. I'll have them up in a few minutes.
Old 09-02-2012, 04:08 PM   #3
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Is it a rectangular 6-pin plug connector (in advance of your posting of pics)?
Old 09-02-2012, 04:09 PM   #4
ttemarantz
Member#: 330344
2005 Wrx
Here they are. Also, my fog lights weren't working when I bought my car and I haven't tried to fix them yet. Could this have anything to do with that?
Old 09-02-2012, 04:11 PM   #5
easterbran
Member#: 307359
'05 STi Stage II
^Pics didn't show up for me...I'm guessing a relay (without seeing pics) because of the lack of fogs. Maybe that's why your fogs weren't working; because the relay was loose in its socket and now it just decided to fall out? They usually fit pretty snugly though.
easterbran is offline   Reply With Quote
Old 09-02-2012, 04:12 PM   #6
ttemarantz
Member#: 330344
2005 Wrx
yes it is, except there's only two pins in it. they look similar to the pins on anything you would plug into a wall. they run sideways and parallel to each other but there not lined up on top of each other
Old 09-02-2012, 04:12 PM   #7
ttemarantz
Member#: 330344
2005 Wrx
where is the place where this relay should be plugged in located?
Old 09-02-2012, 04:18 PM   #8
easterbran
Member#: 307359
'05 STi Stage II
Pop off the coin tray, and you'll see the fuses...then look to the right of the fuses and you'll see a black column with other rectangular relays. I believe the fog relay is in the second slot from the bottom (you may need to pop off the lower dash to access the relays)
Old 09-02-2012, 04:20 PM   #9
easterbran
Member#: 307359
'05 STi Stage II
^^And heads up, they're a PITA to remove, so make sure you have some needle nose pliers or something of the like to remove it in case you put it back in the wrong spot. You'll know it's in the right place when your fogs start working
Old 09-02-2012, 04:22 PM   #10
easterbran
Member#: 307359
'05 STi Stage II
I'm willing to bet you have an empty spot right here
Old 09-02-2012, 05:15 PM   #11
ttemarantz
Member#: 330344
2005 Wrx
I'm currently not near my car to check but it's not a black chip like that. It's a white wiring harness with a black wire with a yellow stripe on it. The wire comes out of the harness and loops right back into it in the spot diagonally to the left of it. The wires about 3-4 inches long
Old 09-02-2012, 09:57 PM   #12
Big-E
Member#: 123843
2016 STI LTD CWP
Ignoring the number of terminals, does it look like this:
Old 09-03-2012, 07:15 PM   #13
ttemarantz
Member#: 330344
2005 Wrx
Yes that's what it looks like. It only has plugs in the top middle terminal and bottom left terminal.
Old 09-03-2012, 07:51 PM   #14
Big-E
Member#: 123843
2016 STI LTD CWP
I believe that on the older GD/GG models that this was some type of test-connector that was taped in place to the harness, above the driver's left foot. Over time, the tape dries-out / separates and eventually this test-connector drops onto the floor.
I wouldn't throw it out. Just put into the glove-box or tape it back to the harness.
Old 09-04-2012, 06:07 PM   #15
ttemarantz
Member#: 330344
2005 Wrx
Yupp, I think I found the tape where it was being held up. Thanks alot man!
