Old 09-02-2012, 06:24 PM   #1
avikm289
Member#: 315748
2012 wrx
White pearl
Default anyone use the morimoto retroquick kit on 2011/2012 wrx
http://www.theretrofitsource.com/pro...roducts_id=254
i installed it about 2 weeks ago, first turn on blew 2 fuses, then it wouldn't work at all. anyone have a in depth better insatll guide, with more detail on wiring? thanks either way
avikm289 is offline   Reply With Quote
Old 09-05-2012, 03:45 AM   #2
DONx3
Member#: 214050
2007 WRX
World Rally Blue
Sign up to this forum: http://www.hidplanet.com/forums/show...Subaru-Impreza
Did you use the supplied relay harness?
DONx3 is offline   Reply With Quote
Old 09-05-2012, 06:12 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this makes me all warm and fuzzy inside
Old 09-05-2012, 02:27 PM   #4
rob1n1
Member#: 276425
2013 335is
Alpine White
At least he's trying to do it the right way...
rob1n1 is online now   Reply With Quote
Old 09-10-2012, 10:07 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
How did you wire it? The relays are there for a reason, startup current on HIDs is WAAAAAY above steady-state values. No blown fuses with mine..
Old 09-11-2012, 02:07 AM   #6
avikm289
Member#: 315748
2012 wrx
White pearl
That was the problem, there walk through is vague on the wiring part but clear with everything else. I'm on that site, same user name as here and I'll be doing more research as I attempt to do it agian
Old 09-11-2012, 10:20 AM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Take your time, and secure/waterproof each plug. You'd be amazed how many things disconnect due to vibrations.. and flickering HIDs reduce their lifetime.
Also, don't forget that the wires after the ballast have a kV-level startup voltage, while the wires into the ballast can flow tens of amps of startup current... so don't shove in a voltmeter everywere, or check for hot wires with your tongue
