Old 09-02-2012, 09:52 PM   #1
Stretchvelcroy
Member#: 299169
2002 Wrx/JDM STi v.7
Dirrrty
Default Ej207 v.7 engine with a v.8 ECU...what definitions?
USDM 02 wrx with ej207 v.7 engine running on a v.8 ECU...
I just want to read and log, not flash yet.
I have everything else installed, jumper block and Tactrix cable.....
I am stupmed on Which rom raider definitions I should I use? The ecu or engine ones?
Yes I am a noob. I live 10 hours from any subaru tuner and do not know anyone who even remotely understand this stuff.. I am determined to learn.
Thanks.
Liz
Stretchvelcroy is offline   Reply With Quote
Old 09-02-2012, 10:01 PM   #2
FDM_SW20
Member#: 191501
02 v7EJ207 WRX
Liz, for just logging you would run the logging definitions (logger.xml). The current ones should be on romraiders website or forums. It won't matter between v7 and v8...
Andy
FDM_SW20 is offline   Reply With Quote
Old 09-04-2012, 10:34 PM   #3
Stretchvelcroy
Member#: 299169
Dirrrty
Turns out I didn't install the open port fully.
Had numbers on my laptop for a few minutes then nothing... I'll keep trying.
Thanks Andy!
I am still curious as to what definitions I WOULD use?
Old 09-05-2012, 06:42 AM   #4
quazimoto
Member#: 70395
There isn't separate definitions other than standard or metric units. ALL the definitions are in the program. It picks what definition it needs to use automatically by the ECU ID handshake.
quazimoto is offline   Reply With Quote
