Old 09-02-2012, 11:38 PM   #1
ImprezaJake
Member#: 257921
2006 Wrx
SGM
Default Car probs...
My car was working perfectly earlier this morning then later this afternoon I randomly stepped on it(the gas pedal) I was going to" redline" it and once I got at 4500-5500 rpms the car would "stop" or "struggle" and wouldn't let me go any further till I shifted. Is this a governor or rev limiter ? If so I've never had these kind of problems ever before. I did notice that my car needs new spark plugs, would that interfere with what my problem is? And my car has been idling low lately and feels like it wants to die sometimes. All help would be appreciated thank you.
ImprezaJake is offline   Reply With Quote
Old 09-02-2012, 11:50 PM   #2
assasain
Member#: 323978
2004 WRX STi
Aspen white
So there I was, beating the **** out of my car. Now it doesn't work, explain please.
car, year, mods, miles blah blah blah blah... also the correct section would help.
assasain is offline   Reply With Quote
Old 09-02-2012, 11:55 PM   #3
D wrx
Member#: 323450
My car did that when the VSS went bad. If it feels like you're hitting a rev limiter.
D wrx is offline   Reply With Quote
Old 09-03-2012, 12:12 AM   #4
somecoolbox
Member#: 328190
Okay, my car recently had similar issues. I'm pro tuned, pushing much more than stock power, and what seems to happen to me (when the same exact symptoms happen to my car) it was just a simple boost leak. Small hose coming from recirculating valve leading to the back side of my manifold had popped off. Happened to pop off a couple more times whenever I'd do a good pull.
Fixed now with hose clamp and no more issues.
Good luck.
somecoolbox is offline   Reply With Quote
Old 09-03-2012, 09:16 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Dear OP, this is another one of your thread fails. Please learn to post in the correct section for the best possible help. Without telling us more information, like mods, miles, etc we really can't help you aside from seeing you tried to beat the car a bit.
Old 09-03-2012, 10:30 AM   #6
ImprezaJake
Member#: 257921
2006 Wrx
SGM
I wasn't "beating" the **** out of my car lol I was actually passing someone and it happened 06 Wrx, 85k full bolt ons I checked everything under the hood and everything looked fine
Old 09-03-2012, 10:30 AM   #7
ImprezaJake
Member#: 257921
2006 Wrx
SGM
What's the VSS?
Old 09-03-2012, 10:30 AM   #8
ImprezaJake
Member#: 257921
2006 Wrx
SGM
Good luck.
I checked all hoses I don't think it's that
Old 09-03-2012, 10:31 AM   #9
ImprezaJake
Member#: 257921
2006 Wrx
SGM
Well I'm usually always on my phone so it doesn't show me everything a computer would
Old 09-03-2012, 12:43 PM   #10
assasain
Member#: 323978
2004 WRX STi
Aspen white
You were trying to pass someone by redlining your car?? sounds like beating on it to me, also unsafe because you were probably speeding substantially.
I'm pretty sure your phone tells you what section of the forum youre making a thread in as well.
Old 09-03-2012, 01:08 PM   #11
bclodfelter
Member#: 288878
2011 WRB STI Hatch
World Rally Blue
It does, im on my phone right now (nasioc app)
bclodfelter is offline   Reply With Quote
Old 09-03-2012, 01:23 PM   #12
damonchoy
Member#: 279935
03 350Z - Summer
97 E36 328i - Winter
Yes it does. I have both the Android and iOS NASIOC apps. I mean, it doesn't show some profile information but it sure does show you what section you're posting in.
damonchoy is offline   Reply With Quote
Old 09-03-2012, 01:36 PM   #13
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
Since when is redlining a STI or WRX beating on it? your car is designed to be driven. Sure you aren't going to pin it every gear and every shift, but if you aren't taking it up to 7k every once in a while you're doing your car an injustice.
My car sees redline every time I drive it. And, it's been solid as a rock driving it like that for 100k miles.
575rider is offline   Reply With Quote
Old 09-03-2012, 04:22 PM   #14
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
What the hell is "full bolt on's?" That's not a mod list. At last I remember (and this is bad but you make so many bad threads it's easy to remember) You had a TBE and intake. That's not FULL bolt ons.
Old 09-03-2012, 04:57 PM   #15
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
Thanks for clarifying. I thought you stepped on your car, which, assuming you're a big huge fat guy, would definitely make it "struggle" as you described.
nhmtns is offline   Reply With Quote
Old 09-03-2012, 04:59 PM   #16
Rex_Revo
Member#: 311324
Need. Any codes in the ECM. If none. Can't help. Change plugs, air filter, fuel filter, and run some fuel system cleaner through it. Then get back to us. We'll be here.
Rex_Revo is offline   Reply With Quote
Old 09-03-2012, 08:53 PM   #17
fixedupwrx92
Member#: 331093
Have a Nice Day? new toSubaru
Ok sorry this is not a reply to.your answer but nasioc wont let me post a thread until 3 replys have been made so:
I have a 02 wrx with a cold air intake aftermarket bov and a 3 inch down pipe to catless exhaust. My problem is it wont idle and i have to feather the pedal to.get the rpms up. But when i unplug my mass air flow sensor the idle goes up to 2000 and is responsive where i can hit the gas with no bogg..... ive replaces maf both o2 sensors checked tps and idac..... also forgot to mention i have had the heads sent out to a machine shop for a full valve job ans resurfacing. My car has been down for 5 months someone please help. Any suggeations?
fixedupwrx92 is offline   Reply With Quote
Old 09-03-2012, 09:38 PM   #18
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
How is the car tuned? AP? Pro tuned with open source? No tune at all?
For the moment.....with no heads on your car, there's nothing you can do anyways. Once the heads are on, get the car tuned by someone who knows Subarus well.
Old 09-03-2012, 10:41 PM   #19
fixedupwrx92
Member#: 331093
I bought it from a guy not knowing what the problem was. It had a skip so i sent the heads out due to a bad valve. The heads are back and the motors in the car fully assembled. Just looking for some advice maybe on what to look for or what to do. I heard that buying a utech ecu would help???? Suggestions?
