Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 09-03-2012, 01:50 AM   #1
TurboLegacy87
Member#: 312287
2002 Impreza outback
Mbp
Default will a ej253 drop in a wrx?
Here's my question, I have a 02 impreza outback sport 5spd. I am getting a 03 wrx wagon auto, minus the motor but with engine harness intact. I'm gonna be sourcing and building a hybrid wrx/sti swap but since I have a complete n.a. drivetrain could I swap the whole motor,5spd trans, pedals into the wrx for the meantIme and will the wiring be good? Or as another option can I keep the auto trans and just drop in the motor for now.?
TurboLegacy87 is offline   Reply With Quote
Old 09-03-2012, 03:09 AM   #2
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
You could put the motor in but thats it. The wiring is different and so is the computer. Sell the impreza and buy a motor, done.
Old 09-03-2012, 03:20 AM   #3
TurboLegacy87
Member#: 312287
Mbp
Is the wiring that such different? I have the ecu for the n.a. motor so that wouldn't be a big deal.
Old 09-03-2012, 03:21 AM   #4
xhector2013x
Member#: 314589
2001 L W/ej251
+1 yeah youd be better off selling the outback to buy a rex motor
xhector2013x is offline   Reply With Quote
Old 09-03-2012, 03:29 AM   #5
TurboLegacy87
Member#: 312287
Mbp
Can't find takers for the outback though hah so figured I'd sacrifice it for parts instead. Didn't think 2500 was too much to ask.
Old 09-03-2012, 03:48 AM   #6
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I just sold my 97 obs on saturday for 2500. I would think an 02 should sell for 2500 easy.
Old 09-03-2012, 12:14 PM   #7
GEE-OTTO
Member#: 201277
2009 Legacy GT
No the EJ205 ECU wont run the EJ253 engine as a simple answer. Second if you want a 2.5 Impreza hatch as the end result I would source a 2.5i (06-09) ECU and harness and install that into the WRX shell. There really isnt a efficient way to the end result
GEE-OTTO is offline   Reply With Quote
Old 09-03-2012, 12:47 PM   #8
TurboLegacy87
Member#: 312287
Mbp
Nonono what I'm saying Is that I have the ej253 ecu to drop in the car with the motor I just want to know if the ej205 engine bay harness is similar enough to run the ej253 till I finish the hybrid build. And mod maniac I wish my car would sell but I can't get any buyers just broke tire kickers.
Old 09-03-2012, 01:41 PM   #9
xhector2013x
Member#: 314589
2001 L W/ej251
if you could just drop an ej253 engine into a wrx wouldnt you think itd be the same for when
people do a wrx and sti swap to other subarus? people spend hours and days merging harnesses to get the engine to work. if only it were as simple as plug and play
and wow man you would think that your outback would sell for that price, how many miles are on it?
Old 09-03-2012, 01:45 PM   #10
xhector2013x
Member#: 314589
2001 L W/ej251
the only 100% sure drop in for that wrx IS a wrx, and maybe an sti im not too familiar with sti though.
Old 09-03-2012, 02:35 PM   #11
TurboLegacy87
Member#: 312287
Mbp
209K on the outback sure it's high but it runs amazing!
Old 09-03-2012, 10:26 PM   #12
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Mine had 189k and they were lined up to take it. I had three peaple who wanted to look at it but the first one took it.
Old 09-03-2012, 10:37 PM   #13
TurboLegacy87
Member#: 312287
Mbp
Maybe it's a western ny thing? nobody wants my car!
Old 09-03-2012, 10:54 PM   #14
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Then try to trade it for an engine, you might get lucky. Post it in the wanted section.
Old 09-03-2012, 11:15 PM   #15
TurboLegacy87
Member#: 312287
Mbp
Someone just buy my car!!
Old 09-03-2012, 11:54 PM   #16
GEE-OTTO
Member#: 201277
2009 Legacy GT
EJ253 ECU wont run a EJ205 easily.
Old 09-04-2012, 12:01 AM   #17
TurboLegacy87
Member#: 312287
Mbp
Noooo the 253 ecu would run the 253 till I finished a 205 build then the 205 would go in with the matching ecu. I'm saying can I put the whole 253 motor ecu and what not into my wrx till I finish the build. I need a car for work.
Old 09-04-2012, 01:34 AM   #18
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Drive the obs, save your money and buy a engine. You would have to hack the wiring and then put it all back. Not worth the work.
Old 09-04-2012, 10:57 AM   #19
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
You could opensource tune the wrx ecu into running the EJ253. Someone on here or on rs25.com did a 2.5i swap into his late 90's impreza using stock wire harness and a wrx ecu for EM. Just read his thread, but can't for the life of me remember his S/N
EDIT: found thread, lol, how do you forget a screen name like carbotron.... Here you go.
~Josh~
Old 09-04-2012, 01:13 PM   #20
GEE-OTTO
Member#: 201277
2009 Legacy GT
OHHHHHHHHHHHH yes you can put the Ej253 drivetrain in the WRX shell just use the right engine mounts and gearbox mounts and make sure the rear diff is the same ratio as the gearbox.
Old 09-04-2012, 01:24 PM   #21
TurboLegacy87
Member#: 312287
Mbp
What about the wiring? The wrx shell has full engine harness intact but I also have my full outback engine harness and ecu.
Old 09-04-2012, 01:55 PM   #22
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The wiring will take you 40-50 hours...
Old 09-04-2012, 11:43 PM   #23
TurboLegacy87
Member#: 312287
Mbp
Are there plugs that separate the engine harness from the main harness before it goes through the firewall? Coming from Honda's they had a engine harness that came together into a thick bundle with two or so big 20 pin plugs. And from the other side of those l plugs it went into the firewall and went to the ecu and dash etc. Are Subaru like this or do you have to unhook the sensors and pull the harness through the grommets in the dash?
Old 09-05-2012, 02:16 AM   #24
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
What advantage do you get from swapping the 253 into the wrx? Now you are driving a different shell with the same internals. What a freakin waste of time. Just drive the obs until you save up enough money or sell it.
geronimo81 is offline   Reply With Quote
Old 09-05-2012, 11:27 AM   #25
TurboLegacy87
Member#: 312287
Mbp
Limited space Is why. Stupid town laws prohibit unreg cars in your driveway even under a cover. It's dumb.
