Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 09-04-2012, 09:03 AM   #1
dans04wrx
Member#: 149689
Default Battery/Alternator
Hey guys, I am having some battery/alternator trouble. I dont want to pay to bring it somewhere to have it checked out. What is the best way to check both so i know for sure it is one and not the other?
Symptoms are as follows, if i leave the car off for about 3 days, the car doesnt start. The engine doesnt even turn. There are lights though. If i start it everyday, it starts, but now 100% normal start. This morning, i tried starting it and nothing. Then i boosted it, left it on for a few minutes, turned it off, then tried to turn it on again and it did not start.
The battery does look to have some kind of corrosion or whatever on the positive terminal.
Essentially, what is the best way to check the alternator/battery to narrow it down?
Thanks
04rex
dans04wrx is offline   Reply With Quote
Old 09-04-2012, 09:35 AM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Autozone, or other parts store should check it for you for free. Otherwise you can get a digital multimeter and check out how many volts the alternator is putting out when the car is running. Should be around 14v iirc. When the car is off, the battery should be putting out 12v.
A way to check if it's the alt is to start the car, let it run for a couple minutes and then disconnect the battery. If the car stays running the alternator is fine.
tebriel is offline   Reply With Quote
Old 09-04-2012, 10:50 AM   #3
dans04wrx
Member#: 149689
I heard taking out the battery terminal while the car is running could damage the computer on the car.
Old 09-04-2012, 10:55 AM   #4
quazimoto
Member#: 70395
Thats correct. That method was used for old ass non OBD cars.
quazimoto is offline   Reply With Quote
Old 09-04-2012, 12:35 PM   #5
philly15
Member#: 223137
14' super ultimate
race car project
Get new battery if you leave it for a couple days and it doesn't start means its not holding the charge if the alternator was bad car would shut off while driving for a while but as stated autozone should check it alternator should put out 14-16 volts best way would to use an amp clamp and see if it's putting out the recommended amperage on the alternator
philly15 is offline   Reply With Quote
Old 09-04-2012, 02:38 PM   #6
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
I didn't know that about obd cars. GTK. Best bet is to just take it to a parts shop and have them test your charging system for free.
Old 09-04-2012, 02:48 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
pre-dating OBD even... Pretty much any vehicle that had any electronic circuit could be fried by taking out the battery.
