South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-04-2012, 02:15 PM   #1
BACANA
Member#: 285053
1998 2.5L
fake WRB
Default help...
^^what does this mean?
BACANA is offline   Reply With Quote
Old 09-04-2012, 02:33 PM   #2
yman
Member#: 199051
04 sti
psm
defroster?
yman is offline   Reply With Quote
Old 09-04-2012, 02:46 PM   #3
BACANA
Member#: 285053
1998 2.5L
fake WRB
its on the leftside of my gauge cluster (v4 JDM Sti)
Old 09-04-2012, 02:47 PM   #4
BACANA
Member#: 285053
1998 2.5L
fake WRB
Originally Posted by yman View Post
defroster?
it came on and now my rs, the engine bogged and died... now it wont start
Old 09-04-2012, 03:04 PM   #5
Psirene
Member#: 308506
2015 Legacy Limited
Crystal Black Silica
This looks like a similar thing. Maybe it's something with a fuse? Still hunting...
http://forums.nasioc.com/forums/show....php?t=2245967
ETA - here's another one, http://www.rs25.com/forums/f190/t175...ing-light.html
ETA2 - http://www.subaruforester.org/vbulle...97/index2.html
From everything I can find, it's the hot CAT warning/CAT temp warning light.
Psirene is offline   Reply With Quote
Old 09-04-2012, 03:49 PM   #6
BACANA
Member#: 285053
1998 2.5L
fake WRB
hmmm.... i did get a CAT code several times in the past year...
after reading that first thread here is some abnormal behavior from my rs:
-all gauges pegged at zero, lights still worked fine (2 weeks ago)
-a/c compressor would turn on and off at random (2 days)
-lights would get brighter when braking (2 days)
-engine sputtered and bogged with too much gas
-finally engine died and wont start
-after sitting for a day, engine started, but only lasted 10 seconds and now wont start or even turn over
Old 09-04-2012, 03:54 PM   #7
Psirene
Member#: 308506
2015 Legacy Limited
Unfortunately in this case, Googling is the extent of my knowledge about this. Hopefully some of the technically adept folks can chime in and help.
Old 09-04-2012, 04:30 PM   #8
BACANA
Member#: 285053
1998 2.5L
fake WRB
story of my life
Old 09-04-2012, 05:24 PM   #9
shwoop_soobie
Member#: 102323
99 power poles
beware
call Barry 602-456-1-STi (784) / JapCarRealGood
shwoop_soobie is offline   Reply With Quote
Old 09-04-2012, 05:49 PM   #10
Psirene
Member#: 308506
2015 Legacy Limited
+1
That'd be your clever person right there.
Old 09-04-2012, 05:57 PM   #11
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
That's the "toast is done" indicator...
duh.
Seriously though, never seen that one before. Have you done an OBD scan on it?
02blkwagn19 is offline   Reply With Quote
Old 09-04-2012, 08:21 PM   #12
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Check your grounds. Those symptoms sound like one's I've had in the past when my battery is going bad or when the connections to the battery or chassis have corroded or are loose.
Old 09-04-2012, 08:48 PM   #13
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Ahhh yes. Now that Ken mentions it, I had similar problems when the ground on the top of the manifold came loose after the bolt fell off. So like Ken said, search that thing top to bottom for lose wires or bad grounds.
Old 09-04-2012, 11:00 PM   #14
BACANA
Member#: 285053
1998 2.5L
fake WRB
after talking with Barry, who says he has never seen that light before!, i will first clean every ground and replace my battery cables, they have quite a bit of corrosion on them... and with a little luck this thing should be running again
Old 09-05-2012, 02:39 AM   #15
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
Thumbs up
This ^ Funny, I told him the vAry same thing!!!
JapCarRealGood is offline   Reply With Quote
Old 09-05-2012, 03:21 AM   #16
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
OMGHi2U
Did you race a Chevy and win?
I'm not 100% sure,
but you may have inadvertently burned a some sort Chevrolet product.
Just a thought, marinate away on that.
Old 09-05-2012, 03:38 AM   #17
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
Caution noob response to follow shortly.
kinda looks like your rear diff sizzling hot?
Edit: forget the noob response here it is
Found the light!
Cat on Fire? "Gato en Lumbre'"
hope that helps.
post #72
http://bbs.scoobynet.com/473747-sti-...-thread-3.html
03.dub.r.x is offline   Reply With Quote
