Old 09-04-2012, 04:45 PM   #1
only2litahs
Member#: 307873
2004 WRX
Question Stage 2 open source/resistor mod help
Have been running an open source stage 2 map (catless up pipe, downpipe, and a free flowing cat back) or with no issues peaking around the 17psi mark for a couple months now. Recently had to take the egt sensor out (p0546) and do the resistor mod until cash is in hand for a new sensor. Also did the ecu reset as found here to relearn current values... Had to reset a couple of times to get "better" response boost wise, but is still not performing to par.
Is there a way to tune around the constant egt reading, or is this something to live with until the sensor is replaced?
only2litahs is online now   Reply With Quote
Old 09-04-2012, 04:53 PM   #2
quazimoto
Member#: 70395
Just disable it in the map. Literally takes seconds. It's in the "emissions" folder.
quazimoto is offline   Reply With Quote
Old 09-04-2012, 05:59 PM   #3
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Pm me for my email address. Send me your map and ill take care of it for you. My turn around time before midnight EST is 45 minutes.
Black94Snake is offline   Reply With Quote
Old 09-06-2012, 02:39 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
EGT isn't used in the tuning. Don't need the sensor and removing it won't change anything about how your car runs. The only function it serves is as a "go / no-go" gauge on the engine. As you probably noticed when you had the CEL, "no-go" really means no go. If it's in 'go" mode you're all good and there's no need to "tune around it" of ever replace the sensor.
Concillian is offline   Reply With Quote
Old 09-06-2012, 05:17 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
Can you monitor the actual EGT temps with this sensor while using a logger? If so it would be really handy to use the already exsisting sensor/harness/ live data readouts etc.... Ive got a STi so im not sure what the purpose is to have it (on the WRX)and not be able to monitor it........im so confused lol
Paidfor is offline   Reply With Quote
Old 09-07-2012, 04:24 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The sensor used is very shielded (slow to respond) and far from the heads. Little meaningful info could be obtained from logging it, but there is a checkbox for it in the logger.
