Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 09-28-2012, 01:00 PM   #1
bm880
Member#: 324299
2001 BUG
Default bolt fell inside clutch housing
hi guys, i was changing my bpv hose... when i was tightening up the bolt..it fell inside the clutch housing, the problem is i cant locate it, i know it dropped there because i saw it, even using a flashlight i couldnt locate it, theres any way to remove it in my garage? it will damage my clutch if i try to start the car and ride it? any help will be appriciated! TY !
bm880 is offline   Reply With Quote
Old 09-28-2012, 01:24 PM   #2
68Cadillac
Member#: 95901
Magnetic wand might get it.
Yes it will eventually damage your clutch/flywheel/starter. A hard turn or bump will knock it loose and into the moving parts. You have to get it out.
You may have to take the clutch fork out to get a better angle at it. Pop the clutch fork grommet first before pulling the whole fork, and see if you can get it that way. If you can't you'll have to separate the tranny/block.
68Cadillac is offline   Reply With Quote
Old 09-28-2012, 01:27 PM   #3
68Cadillac
Member#: 95901
Also:
<---fill out your profile. At least Model and Year.
Old 09-28-2012, 05:25 PM   #4
bm880
Member#: 324299
2001 BUG
do i have any access underneath the car ?
Old 09-28-2012, 05:39 PM   #5
biodude
Member#: 271720
theres a dust shield, it wont get you past the flywheel, but maybe you'll be able to see where the bolt landed to try to snag it from above with a magnetic wand or one of those claw gripper things
biodude is offline   Reply With Quote
Old 09-28-2012, 05:53 PM   #6
nomoredsm
Member#: 281987
2007 wrx
blue
Harbor freight sells a knock off color screen boroscope for $90. Google harbor freight coupons and print out a 20% off coupon and get it for like 77 after tax. It works real nice but it will not fit in spark plug hole
nomoredsm is offline   Reply With Quote
