Old 09-05-2002, 12:25 PM   #1
Foovanadil
Member#: 23515
2011 Legacy GT
Steel Silver Metallic
Default Reverse Indiglo Gauges Power Supply?
Hey guys I've got a question. I just installed reverse indiglo gagues in my 02 WRX but they didn't come with any instructions so I had to figure it out myself. Well I got them put in ok but I'm stuck trying to figure out which wire I tap into to get the power feed? I'm assuming I can tap into the parking light feed but which wire is that? (color and location would help) I got the gauges from www.redlinezone.com has anyone else installed these gauges that could give me some help. Thanks in advance for your help
Foovanadil is offline   Reply With Quote
Old 09-05-2002, 12:37 PM   #2
HpiRally
Member#: 3864
I am unsure if the wires are the same, but on the MY98+ Imprezas the parking light wire is in the center wiring harness. The colors are yellow with a black line down it.
Joe
HpiRally is offline   Reply With Quote
Old 09-05-2002, 01:08 PM   #3
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
On the third wiring harness (that's closest to the radio) in the back/bottom of the cluster (they're green?), tap into the purple wire for power and the black wire for ground.
-Mike-
CreoWRX is offline   Reply With Quote
Old 09-05-2002, 01:26 PM   #4
Foovanadil
Member#: 23515
2011 Legacy GT
Default Just to be clear
Your talking about the plugs that go into the Gauge pod correct? or are you talking about the wiring that comes from the steering column? As I read it I have to tap into a purple wire coming out of the far right (as your facing the dash) wiring harness that plug into the gauge pod and then ground it with the black wire. Is that right? Sorry for the dumb questions but electrical scares me!
Old 09-05-2002, 02:59 PM   #5
98kPa
Member#: 17379
I used the org/wh and violet wires from the fog light buttons. It works, but I'm considering moving them. I was going to hook them up to the power supply for the combination meter, but it might make it a pain to take out.
jason
98kPa is offline   Reply With Quote
Reverse Indiglo Gauges Trueday Interior & Exterior Modification 1 06-11-2002 08:40 PM
95-96 reverse indiglo gauges noahr Legacy Forum 2 05-24-2002 12:30 AM
Wrx Reverse Indiglo Gauges FuJi K Interior & Exterior Modification 3 05-09-2002 02:08 AM
reverse indiglo gauges spacemonkey Interior & Exterior Modification 2 03-21-2002 10:47 PM
