Old 10-10-2012, 06:42 PM   #1
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Default Boosted Tuning Remote Tune: 05 WRX, Stg. 2 & Stg. 2+VF22 dynos
Event: Remote Tune
Car: 05 WRX
Tuner: Jay @ Boosted Tuning (www.boostedtuning.com)
Dyno Info: Virtual dyno
Transmission: Stock 5sp
Gear: 3rd
Target Boost: 18psi
Target AFR: 11.0-10.7 AFR
Fuel: 91oct
Engine/Power Modifications:
1st DYNO
APS 65mm intake
Perrin Turbo Inlet
3" DP
test pipe
3" exhaust
catless uppipe
Walrbro fuel pump & Modded Stock Injectors
Forge MBC
2nd DYNO - Added the following:
vf22
Ebay tmic
EL headers
** Back to back pulls shown, to show that power is consistent and that dyno numbers are not a one time VD fluke. (I feel this should be done with all VD charts/results) **
Boosted Tuning is offline   Reply With Quote
Old 10-10-2012, 08:01 PM   #2
kaj
Member#: 290109
2005 WRX
i have to admit that car was a blast to drive. i miss it a bit. until i get in the new car. LOL
kaj is offline   Reply With Quote
Old 10-11-2012, 12:16 PM   #3
FCmaniac
Member#: 142029
2013 Fozz
2004 STi, 1991 Miata BRG
Is the car running stock 05 WRX injectors with the vf22??
FCmaniac is offline   Reply With Quote
Old 10-11-2012, 01:17 PM   #4
Subian
Member#: 202804
2002 PSM Sedan
20g/ewg/Phattbotti Tuned
Especially with the EL header, you should be able to squeeze more boost out of that vf22. I had a similar setup with a Grimmspeed EBCS and ran 21 psi and make 290ish on the VD "dynojet" setting. It's all up to the consumer though if he wants to push the car a bit. Also noticed this was on 91 octane.
Subian is offline   Reply With Quote
Old 10-11-2012, 03:02 PM   #5
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
It had modded stock injectors. Forgot to add that.
Yeah, we coulda pushed it more, but it was on 91oct and the client saw no need to push it harder.
Old 10-14-2012, 11:14 PM   #6
kaj
Member#: 290109
2005 WRX
the 1.5 scroll ELH made the car sound awesome and is really the only reason i installed them (i'm not a fan of the Subaru noise). LOL. it turns out spool and top end benefited GREATLY. that was an added bonus.
Old 10-15-2012, 10:40 AM   #7
Subian
Member#: 202804
2002 PSM Sedan
I'm an idiot...
Old 10-15-2012, 10:45 AM   #8
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Looks great! Top end is so much stronger!
Great use of Virtual Dyno. Nice consistent results.
Where do you see boost on the street?
Those are logs from street pulls.
Old 10-15-2012, 07:57 PM   #9
kaj
Member#: 290109
2005 WRX
yes. i can't remember the last time we've used a dyno.
Message Board Statistics All times are GMT -4. The time now is 05:09 PM.
