Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 08-24-2012, 11:51 AM   #1
flacopower
Member#: 226984
2002 wrx
Default 7 MPG drop while using AC
My commute is roughly 46 miles RT with 70% being highway. Per my scangauge 2, I've been averaging 19mpg per tank while driving very modestly. Yesterday, my AC belt snapped off at the very beginning of my commute home. So I just rolled the windows down and drove like normal. I replaced the belt last night.
Well today I checked the scangauge and was shocked to see I had gotten 25MPG yesterday (including the morning commute w/ AC on). I left the AC off today and returned 26.5MPG. On the highway, as soon as I turned on the AC the mileage dropped immediately back into the teens. I know AC causes parasitic loses, but doesn't 27% seem really high? Is this a sign my AC is not operating correctly? Additionally, what can I do to decrease the MPG drag of my AC?
CLIFFS: Belt snapped yesterday so no AC, registered 7MPG higher (per Scangauge 2) than normal commute.
Is my AC operating correctly?
flacopower is offline   Reply With Quote
Old 08-24-2012, 11:57 AM   #2
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
It would have to be a pretty dry rotted belt to snap, so your compressor may be really tight and about to seize.
However, I'm not convinced any scan tool can accurately measure MPG given the variable of fuel returned to the tank etc.
NitroTrike is offline   Reply With Quote
Old 08-24-2012, 12:35 PM   #3
flacopower
Member#: 226984
2002 wrx
not trying to sound defensive, but the scangauge is pretty accurate. by most estimation within 5% when i calculate miles driven/gallons to fill up tank
Old 08-24-2012, 12:36 PM   #4
flacopower
Member#: 226984
2002 wrx
please tell me more about my compressor being tight. what does it mean, how do i measure, any preventative measurses?
this is the second belt in two and a half years and the last one was an oem belt
Old 08-24-2012, 12:58 PM   #5
zashoe
Member#: 329523
2002 Impreza WRX
World Rally Blue
I agree about the compressor being tight. belts generally don't just snap. I'm honestly not sure how to test it. but they aren't too much at a salvage yard.
zashoe is offline   Reply With Quote
Old 08-24-2012, 06:39 PM   #6
NitroTrike
Member#: 62408
I'm surprised it's that accurate. I wonder what algorithm the Scangauge uses to "know" the fuel pump flow and the gazillion of other variables that don't even have sensors to monitor.
Anyway, back to the compressor issue. Was the belt just cleanly snapped, or was it burned / stretched at the break? If it was burned, the belt was just loose and the crank pulley spun in it until it let go. Was it squealing at all prior to breaking?
Has the A/C recently been charged? An overcharge will cause compressor stall / lockup too, but I'm not sure how much harder it will be to turn before this happens.
Nothing really explains the 27% difference though - but a silly question, since it's a bugeye.. have you had the fuel line recall / update done?
Old 08-25-2012, 11:28 AM   #7
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
w/ the AC on and your given situation which i dont really know it could be putting you in OL fueling and dumping more fuel in w/ the AC on. like being on the very edge of the engine load scaling and then when the AC goes on the engine load goes up and moves over to the next cell. is your car tuned? stock map? that info would be helpful. also how tight was your belt? belts even after dry rotting last years.
WhiteBgeye02 is offline   Reply With Quote
Old 08-26-2012, 02:14 AM   #8
Uncle Scotty
OK Houston
we have an Uncle
in cant believe a 7mpg difference witout something being broke somewhere....ac clutch bearings going bad or idler pully bearings or the tune being on the edge of ol
is the fuel filter clogged???
Old 08-26-2012, 01:39 PM   #9
flacopower
Member#: 226984
2002 wrx
Fuel filter was changed a couple years ago, I'm still on stock tune. My only mods are downpipe and intake. Only code is p0136 (rear 02 sensor wiring)
Old 08-26-2012, 04:48 PM   #10
flacopower
Member#: 226984
2002 wrx
Just cleaned air filter and maf.
Also going to change pcv valve.
Do you guys think it could be the front o2 sensor (even if I'm not throwing a code?) I was getting an overboost code a while back...
Old 08-26-2012, 06:47 PM   #11
Uncle Scotty
OK Houston
we have an Uncle
change the fuel filter...reset the ecu
Old 08-26-2012, 08:31 PM   #12
flacopower
Member#: 226984
2002 wrx
Ok... Will do tomorrow. Is there anyway to be able to tell if the fuel filter is bad?
Old 08-26-2012, 09:19 PM   #13
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
I noticed a pretty sizable drop with a/c on as well, this was while cruising at 70/75 however. At 90 today, with a/c on it was in boost the whole time lol. Oh dear. You could pretty much see the gauge going down.
tebriel is offline   Reply With Quote
Old 08-27-2012, 01:42 AM   #14
Uncle Scotty
OK Houston
we have an Uncle
i think that's a REAL good indication, there
Old 08-27-2012, 01:44 AM   #15
Uncle Scotty
OK Houston
we have an Uncle
yet another reason i like my 06....i can go 90 all day long at 100*F, ac on '2' and get 23-24mpg
Old 08-27-2012, 10:31 AM   #16
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
Well yeah that's probably what I was getting. This drop is down from 30mpg.
Old 08-27-2012, 10:39 AM   #17
1122bugeye
Member#: 296857
sedona red
i just made a lon trip (10 hours each way to the beach and back home) on the way there i got 29-30mpg with no ac. on the way home i was getting around 21-22 with ac on the whole way. gf was cryin cause it was hot out. so it does drop a good bit
1122bugeye is offline   Reply With Quote
Old 08-27-2012, 01:12 PM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
all it needs to know is injector on time and vehicle speed.
Old 08-27-2012, 08:52 PM   #19
knotcher
Member#: 330463
don't trust the scangauge...test it a bit more before you try and fix anthing. teh AC doesn't pull that much and shouldn't make that much of a difference
knotcher is offline   Reply With Quote
Old 08-28-2012, 09:23 AM   #20
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
You need a tune for a downpipe
indytruckboy is offline   Reply With Quote
Old 10-22-2012, 01:04 PM   #21
Flying Hombre
Member#: 331272
2003 WRX STi Hybrid
What would cause a compressor to become tight? Was the AC system recently recharged?
Flying Hombre is offline   Reply With Quote
Old 10-22-2012, 02:41 PM   #22
Andrewxxcarlson
Member#: 316415
2006 WRX
Andrewxxcarlson is online now   Reply With Quote
Old 10-22-2012, 10:01 PM   #23
Uncle Scotty
OK Houston
we have an Uncle
not for the bugeyes ya dont
Old 10-24-2012, 12:18 AM   #24
silverbulletwagon
Member#: 335963
Default weird
there is major drag somewhere?
silverbulletwagon is offline   Reply With Quote
Old 10-26-2012, 01:09 AM   #25
Grippen
Member#: 329712
2005 Sti
My 05 does the same exact thing as yours. When my a/c is on the car is gets 2-3mpg less, give or take a few. Not sure...
Grippen is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 01:25 AM.
