Old 09-06-2012, 02:15 AM   #1
Brad07wrx
Member#: 329485
Default Prosport gauge
So I got a little older prosport boost with the single mount pod, wiring harness, clear lines, brackets and screws. Do I need a boost sender too?
Brad07wrx is offline   Reply With Quote
Old 09-06-2012, 09:27 AM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Wrong section. Fill out your profile. Call Prosport for the most ACCURATE answer.
Old 09-06-2012, 12:39 PM   #3
silmarilion
Member#: 191270
06 STI
I would say that yes you do
silmarilion is offline   Reply With Quote
Old 09-06-2012, 01:18 PM   #4
StealthTL
Member#: 206912
2006 Forester XT
By clear lines, do you mean plastic tubing?
The tubing connects to the vac source.
Only the electrical one uses a sender.
StealthTL is offline   Reply With Quote
Old 09-06-2012, 01:19 PM   #5
Source,LLC
Member#: 322524
3.5 WRX STI
if its mechanical you do not need a sender unit, otherwise you will. If there is a nipple on the back of the gauge to hook up a vac line then you're good to go.
Source,LLC is offline   Reply With Quote
