09-06-2012, 01:29 PM | #1 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
LOW MOUNT TURBO KIT - Prototype - Killer B Motorsport
Dyno: Nightshift
Tuner: JR-Tuned Wheel HP: 460 Wheel TQ: 390 Ambient Temp: 108 Elevation: New Jersey Car Info Year: 2005 STi Engine Management: Cobb AP SD Turbo: GTX3576-R (Tial 0.82 A/R, Modified Compressor Inlet: from 4" to 3") Target Boost: 24psi WasteGate: Tial MV-S (VTA) Intercooler: Killer B Motorsport Low Mount Prototype Fuel: Pump 93 Injectors: Injector Dynamics 1,000cc Intake/Inlet: 3" air filter on turbo Headers: Killer B Motorsport Low Mount Prototype Uppipe: Killer B Motorsport Low Mount Prototype Downpipe: Killer B Motorsport Low Mount Prototype - Catted Radiator: Killer B Motorsport Low Mount Prototype CBE: MadDad Whisper Other: Stock heads, shortblock with Sleeves, Copper O-Rings, Manley H-Tuff Rods, Manley pistons, Manley Billet Crank Tial Q BOV, stock size blow thru MAF, Omni 3-bar, Crawford A/O Sperator, Mocal Scavenge Pump. Killer B Motorsport Low Mount Prototype Turbo Sump, 340 Fuel pump, Aeromotive Pressure Reg., Killer B Motorsport Oil Pan, Pickup and Baffle. This was some testing of our Low Mount Turbo Prototype Project. Previous testing (GTX3071-R) netted 401whp with a 0.82 A/R housing with a spool reduction of ~150RPMs with power taper ~7,500RPMs (too high for stock heads IMO). This was the first part of testing on the second revision. Testing from 6-3-13
09-06-2012, 01:59 PM | #2 |
Member#: 113096
SWIC
Vehicle:06 sti |
thats pretty sweet! always nice to see something new
I am really interested on what this could do with some good fuel Last edited by Got Boost?; 09-06-2012 at 02:59 PM. |
09-06-2012, 02:36 PM | #3 |
Member#: 278519
SCIC
Vehicle:30r E85 sti 450+whp kb'izzle |
reserved, ^^ what he said
09-06-2012, 02:56 PM | #4 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
Badass. I talked with you guys a while ago about this kit
09-06-2012, 02:58 PM | #5 |
Member#: 128760
RMIC
Vehicle:2017 STI Silver |
Very Nice, Almost what Subaru is doing now with the new set up. Interested to see how this one will work out.
09-06-2012, 03:35 PM | #6 |
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
Wow what a nice looking powerband. The spool is fantastic, wish it still had the .82a/r though...
09-06-2012, 04:18 PM | #7 |
Member#: 170007
BAIC
Delete
09-06-2012, 04:37 PM | #8 |
Member#: 26530
South East
Vehicle:2004 Sti JBP |
Very cool, I can't wait to see what the GTX3576R will do w/ your low mount kit.
Any reason you decided to keep it single scroll? Also as stated above, got any pics with the front bumper off? |
09-06-2012, 04:40 PM | #9 |
Member#: 197062
I second the need for pictures without the front bumper.
09-06-2012, 05:28 PM | #10 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
Will the bigger turbos still fit? And if so do you think the weight will cause any issues? I'd part with my kit for something like this.
09-06-2012, 05:53 PM | #11 |
Member#: 170007
BAIC
Delete
09-06-2012, 06:01 PM | #12 |
Member#: 284866
South East
Vehicle:1998 Full RSTi Swap Metallic Grey |
How is the intercooler setup?
09-06-2012, 06:48 PM | #13 |
Member#: 198281
Guys, thanks so much for the kind words!
The goal of this kit is to provide OEM responsiveness (+200wtq by 3,000 RPMs, with the pull starting at 2,500RPMs) but provide significantly more power. Making big power is good fun, but I really didn't want to take a hit in streetability, because I want to DRIVE it everyday and not have to rev it to the roof to make the power... And track competitiveness and reliability is important as many of us often find outselves at a motorsports events on the weekends Here is a plot with the 0.82 A/R, showing power going a bit higher in the revs than I'd like for OEM heads, but we were curious when it started to fall. The car drove fairly well, but the tune needed improvement, as the plot shows, and I really wanted to go Speed Density as well as make a few other small changes. So I swapped the housing and headed to EFI Logics. Worked with Garrett on this part. According to some simulations and actually testing they had previously done, this housing 'adapter' actually improves surge characteristics and has no negative effects on power capability. So far, we can't tell any difference. Here the scavenge pump. Took a bit to get it sorted out, but it works flawlessly now Bracket mounts to OEM tapped holes and is made from 1/8" thick stainless. Mock up bumper beam shown here. The 'real' one is 1" square solid steel. Intercooler end tanks are just tacked together here and the the radiator placement tested. Extremely close to the end fitment. Real bumper beam shown here with bumper mounting points and intercooler mounting. Pluming from compressor outlet to intercooler inlet is ~9" total, so shorter and with fewer bends than an OEM TMIC. Exhaust gasses perfectly straight in and straight out. This gives the absolute maximum potential turbine efficiency. According to Garrett anyway, who am I to argue Guys thanks again! As always, the comments, questions and concerns are always welcome. Since someday this may be an available product, we want to make sure we don't miss anything |
09-06-2012, 07:04 PM | #14 | |||
Member#: 198281
I researched and shopped for cores for a while as I'm not one to cheap out. The core dimensions are 10.5" x 18" x 4.5" The custom grill insert moves the plate out of the way and closes off the edges to make sure air goes through, not around. So far temps have been in check even after several loaded pulls. On the street is stays cool, cool enough that I have stopped monitoring intake temps. |
09-06-2012, 07:07 PM | #15 |
Member#: 133597
SCIC
Have any pictures of the engine/coldside piping? Sweet kit!!
09-06-2012, 07:29 PM | #16 |
Member#: 198281
^ Here's an old CAD sketch and a top pic of the I/C to throttle body. From compressor to I/C it's compressor outlet, silicone 90°, coupler, silicone 45° and intercooler inlet. That's all
09-06-2012, 07:31 PM | #17 |
Member#: 198281
Oh and to answer a few future questions.. There is no turbo coolant reservoir since it's no longer needed. There is a vacuum manifold coming off the turbo inlet so there is still a vacuum source for the Crawford A/O seperator, Fuel purge, etc.
09-06-2012, 07:59 PM | #18 |
Member#: 204652
this looks awesome, is the down pipe 3inch?
09-06-2012, 08:06 PM | #19 |
Member#: 170007
BAIC
Delete
09-06-2012, 08:21 PM | #20 | |
Member#: 198281
Yes
It wouldn't take a lot to go BIG if you you wanted to do some fab work on your own. Right now we want to stay as 'bolt-on' as possible. |
09-06-2012, 09:38 PM | #21 |
Member#: 203011
NWIC
Vehicle:04 WRX Aspen White |
Will your kit include the IC/Radiator/scavenge pump? Or just turbo and piping? Any projected release dates/pricing?
09-06-2012, 10:33 PM | #22 |
Member#: 170007
BAIC
Delete
09-06-2012, 10:52 PM | #23 |
Member#: 239659
SCIC
Vehicle:STI Mikey & Phatron Tuning Da Subies |
might want to think about putting some metal rings on the silicone inlet to prevent collapsing...ala APS
09-06-2012, 11:55 PM | #24 | |||
Member#: 198281
With the cheapo stuff on there we never saw or had any syptoms of collapse in the year we drove it. If it was smaller than 3" I'd be concerned. Plus the legs are pretty short so it would take a boatload of vacuum to make it collapse. |
09-07-2012, 12:10 AM | #25 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
and EFR not available in v-band!
Killer-B Thank you for developing products for our cars! |
