#1 |
Vendor Sales Rating: (18)
Member#: 853
Vehicle:2011 STI Sedan Satin White Pearl |
Service & Maintenance Sales @ Performance Auto Solutions
NASIOC members get an extra 5% off & a Free JDM Squash Air Freshener with ANY of the below packages. This sale is going on through 9/14/12 in preparation for our Nassau Coliseum SCCA Subaru Auto-X event. 631-858-0312 info@performanceautosolutions.com Email, Call or Stop by for details on: -Gates Timing Kits Installations (kits in stock/available): There's nothing worse than a broken timing belt. Or a water pump that can't keep your car efficiently cooled. The Gates Timing Belt kit comes with all new components, including a water pump, timing belt, tensioner, associated gaskets, hardware and pulleys to freshen up your timing belt system. This is a must for higher mileage cars, recommended service intervals & the overall health of your Subie Gates Timing Kit Installed: $800 (new -- timing belt, tensioner, pulleys, water pump, gaskets, thermostat & fluids) ![]() -Spark Plugs (NGK & OEM Subaru in stock): A fouled or worn out spark plug can wreak havoc on your Subaru motor. Causing misfires and acceleration stumbles. Get them changed before you experience any of these conditions or at the recommended service interval. Spark Plugs Installed: $165 (NGK or OEM Subaru) ![]() Fluids Changed & Flushed (Subaru Extra-S & Synthetics on hand): Keep your chemicals clean. Flushing & replacing your coolant before winter is a good way you keep your car happy. Brake fluid burnt or seen lots of heat cycles? Get it flushed and replaced for consistent stopping power. Transmission feel a little "off" during shifting? Let's drain & replace the fluid for smoother shifting. Oil change w/OEM Subaru Filter: $40 (non-synthetic) Oil change w/OEM Subaru Filter: $65 (Subaru Synthetic) ![]() Walbro Fuel Pumps: (GS342 in stock) Got fuel? Now you do. The Walbro 255lph fuel pump is a perfect solutions for keeping your fuel requirements in check. Reliable & affordable. Installed Pricing: $165 DW65c & DW300 are also available for installation. ![]() AP Pro-Tunes (always in stock): More power? Better drive-ability? Stop in for a dialed-in custom tune to keep your Subie happy. Pricing can vary depending on year, model & options. Contact us for details... ![]()
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Member#: 853
Fast Friday Bump Up
__________________
#3 |
Member#: 853
Happy Wednesday everyone!
__________________
#4 |
Member#: 853
Thumpin Thursday! The northeast is creeping towards winter -- make sure your car is serviced before the cold sets in for good!
__________________
#5 |
Member#: 853
Thursdayyyyy Bumpppp!!
__________________
#6 |
Member#: 853
To the Top
__________________
#7 |
Member#: 853
__________________
#8 |
Member#: 853
Thirsty Thursday Deals Don't Forget To Check Them Out!!
__________________
#9 |
Member#: 853
Bump!!!!
__________________
#10 |
Member#: 853
Happy Wednesday Everyone -- it's cold out there -- so keep that car running it's best with preventative maintenance! Packages are available at PAS!
__________________
#11 |
Member#: 853
Bump..
__________________
#12 |
Member#: 853
Friday Bump...
__________________
#13 |
Member#: 853
Happy Tuesday
__________________
#14 |
Member#: 853
To the top!!
__________________
#15 |
Member#: 853
Friday Bump
__________________
