Old 09-06-2012, 06:30 PM   #1
dirt and road
Member#: 293284
2005 2.5 RS
grey meta
Default Head Gasket Seaping?
So my dealership just told me that my head gasket is seaping, which i kind of new was already going on. But my question is what exactly does seaping mean? Car runs fine and somehow ive been getting 35 miles to the gallon on the highway...
dirt and road is offline   Reply With Quote
Old 09-06-2012, 06:40 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Means nothing usually. Leaking/blown are issues, but seeping a bit of oil is really common. Gives you something to watch out for though.
cal_look_zero is offline   Reply With Quote
Old 09-06-2012, 07:45 PM   #3
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
Took mine to the dealership for what I thought was an oil leak and was told it was seapage too. They showed me it hadn't leaked on to anything so I was fine. I was actually smelling burning oil though which was annoying
Imprezzedwitsubies is offline   Reply With Quote
Old 09-06-2012, 09:55 PM   #4
ShinjiML
Member#: 257231
2011 STI
I've been told the same thing and they even tried to get me to do the headgasket, but there's no ACTUAL oil dripping or any other signs of a bad headgakset, just the occasional burning oil smell from the seepage.
If you're not having any issues with Oil and coolant mixing or temperature issues, then the worst case scenario is an external headgasket leak, which doesn't really seem harmful and people put on 30k-40k miles with no problem.
ShinjiML is offline   Reply With Quote
Old 09-06-2012, 10:00 PM   #5
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Just FYI, if you're smelling burning oil and a shop (or someone) tells you it's the head gaskets, just make sure it's not leaking for the rear main seal or oil separator plate or elsewhere. That's where mine is leaking right now (rear main) . Some of it drips onto the exhaust headers and burns nicely there.
Edit: Oh and the car should run just like normal as long as oil levels are kept up. At some point you'll start to loose compression (technically I suppose that you've already lost a very tiny-negligible-amount of compression if it's seeping) on whatever cylinders are affected. But you probably wouldn't notice until the gasket really blows.
tibug is offline   Reply With Quote
Old 09-06-2012, 10:07 PM   #6
dirt and road
Member#: 293284
2005 2.5 RS
grey meta
I burn coolant not oil, atleast i cant smell oil.
Old 09-08-2012, 11:26 PM   #7
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
If you are leaking coolant externally use the subaru coolant additive that is what it is for and it works.
