Old 09-06-2012, 06:39 PM   #1
derekod
Member#: 291643
2004 STi
WRB/Black
Default Radio, clock, and a/c blower coming on intermittently?
So I have an aftermarket radio (Pioneer AppRadio) and the other day I unplugged my iPhone (which gets charged by the radio) while the radio was on to answer a call. Suddenly the radio, clock and A/C blowers stopped working. I pulled the radio, clock, and blower fuses and they all looked good. Put them back in and everything came back on as if I disconnected and reconnected the battery (i.e. the clock needed to be set to the appropriate time and the radio came on as if it was booting up for the first time)
So I headed back on my way home and maybe 5-10 mins later it all shut off again, but then came back on within a minute or 2. Then this morning I start the car, everything is fine but the radio, clock, etc. shuts off in about the first 2 mins of driving and stays off for the duration of my trip (~30mins). Then when I get back in the car it starts up again but shuts off in 2 mins and stays off for about 25 mins when it then suddenly comes back to life. So I'm pretty confused as to whats happening here, any ideas??
It's also worth mentioning that the head unit has been in the car for almost a year now and I have never experienced any of these issues until yesterday. It also isn't coming on or going off when I hit a bump or something like that, so I wouldn't say this is a loose wire problem. I think it has to do with me unplugging the iPhone while the radio was on cause thats the moment this issue began.
Thanks in advance for any help!!
derekod is offline   Reply With Quote
Old 09-07-2012, 12:56 AM   #2
CHR1S H4NSEN
Member#: 330050
I'd say get the alternator checked as well as the battery.
CHR1S H4NSEN is offline   Reply With Quote
Old 09-07-2012, 09:09 AM   #3
LIChuck
Member#: 266122
2007 WRX Limited
UGM
You are periodically losing power and then it fixes itself and you don't think it's a loose connection? The only other explanation is that your system is demon possessed.
LIChuck is offline   Reply With Quote
Old 09-07-2012, 12:30 PM   #4
derekod
Member#: 291643
2004 STi
WRB/Black
haha well..maybe it is But I say it's not a loose connection because the second I unplugged my iPhone, that's when everything shut down and this problem arose. So it has to be something with that...
Could a defective radio somehow cause my clock and a/c blower to shut down periodically??
Old 09-07-2012, 12:37 PM   #5
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Not likely, you should blow a fuse first. I know that the clock and the radio share power, not sure about the blower. Remember to check the grounds as well as the 12 volt power, something is loose.
Glad you appreciate my sarcasm
Old 09-07-2012, 01:20 PM   #6
derekod
Member#: 291643
2004 STi
WRB/Black
Sir, sarcasm is my second language ok I'll take it out and check the ground and power though I feel for some reason still something else causing it. But guess I can't rule things out until I test right?
Old 09-08-2012, 12:44 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
After looking at some service data I suggest you get a test light probe and use it to check for power on fuses 4,9,14,and 15 while the problem is occurring. Those fuses tie to the ACC power of the ignition switch which is also ON with the key in the RUN position. The switch contacts may be intermittent. Along with the things you mentioned the mirrors and wipers are on those power circuits so if they also don't work, then the trouble is most likely with the ignition switch contacts.
Old 09-08-2012, 01:11 PM   #8
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Next time it goes out, test other things and make a note of what all electrically is not working, air, lights, mirrors ect. And when it starts back up check all the items that went out.
tjmmason93 is offline   Reply With Quote
