Vancouver Impreza Club
Old 09-07-2012, 02:23 AM   #1
ida
Member#: 331364
2008 sti
white
Default CEL p2441
Hi,
my '08 STI has a code p2441, secondary air intake valve stuck closed. With the research I've done, if its stuck closed, you don't need to change it or get block off plates, you only need to delete this code. What is the best and easiest way to delete this code? Anyone with a Cobb AP or Tactrix cable that could help out?
ida is offline   Reply With Quote
Old 09-07-2012, 07:30 AM   #2
HRCboy
Member#: 167075
08 STI & 999R
Wow 6 of 7 post with the same question.
You'll need the block off plates to do it right. It might be stuck closed now but might be stuck open later. Once you remove the codes permanently you will never know.
Try deleting the codes I'm sure you will get one down the road the will read it's stuck open. For all you know it the valve could be stuck half closed.
Don't cheap out on such a easy fix especially when you are currently selling ur car with your 7th post.
HRCboy is offline   Reply With Quote
Old 09-08-2012, 03:59 AM   #3
ida
Member#: 331364
2008 sti
white
Thanks for the suggestion. I probably will take it up to Rocket Rally and have them do it 'properly'. I was trying to avoid a $1000 bill, but I guess I have to bite the bullet on this one.
What would your choice be, Cobb or Ecu tec?
Old 09-08-2012, 04:14 AM   #4
HRCboy
Member#: 167075
08 STI & 999R
Cobb then you can flash stage 1 and have some fun with the car. It's a nice tool for scanning codes as well. You can also sell the accessport when you do decide to sell the car.
Old 09-09-2012, 03:27 AM   #5
ida
Member#: 331364
2008 sti
white
Thanks.
Old 09-09-2012, 05:02 AM   #6
0'10sti
Member#: 228533
'10 sti
swp
Try giving a few revs after you start the car. It worked for me. I use to get that code all the time on a cold start until I used that trick.
0'10sti is offline   Reply With Quote
Old 09-09-2012, 02:41 PM   #7
ida
Member#: 331364
2008 sti
white
Thanks for that tip, will give it a try.
Old 01-10-2013, 11:01 AM   #8
StiBoost21
Member#: 317951
07 STI
Did this ever work for you?
StiBoost21 is offline   Reply With Quote
Old 04-06-2013, 01:32 AM   #9
subikid03
Member#: 348321
Question
will it work on my 07 sti limited...have the CEL P2441 valve stuck closed...so when i turn it on it should go away????
subikid03 is offline   Reply With Quote
Old 04-06-2013, 10:46 AM   #10
slowguy
Member#: 4326
only way to find out is to try.. lol
i got the p1410 on my 2010 and just ordered thed blockoff plates right away.
slowguy is offline   Reply With Quote
Old 04-06-2013, 01:42 PM   #11
Karmalina
Member#: 308597
2007 WRX Limited
Urban Gray Metallic
I hate this stupid freaking valve so damned much.
Still waiting for my block off plates to come in the mail.
I finally got tired of resetting my CEL every 1-2 days so now I just stare at the idiot lights...it's almost christmassy.
At least Lance @ Cobb Surgeline has already set me up with the new maps for my tune, they rock.
Karmalina is offline   Reply With Quote
