Old 09-24-2012, 04:05 PM   #26
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
I'd steer away from Gunk. It's been known to strip/dull paint. As with Scrubbing Bubbles, you have nothing to worry about.
2.5L Monster is offline   Reply With Quote
Old 09-24-2012, 04:41 PM   #27
LynyrdSkynyrd
Member#: 113731
2004 WRX Wagon
I've always used simple green or any kind of cleaner let it sit for awhile and use a power washer on a low setting and just stay away from electrical components/wiring or cover them up.
LynyrdSkynyrd is offline   Reply With Quote
Old 09-26-2012, 04:22 PM   #28
GrizzlyAdams
Member#: 235038
2003 WRX
Scrubbing bubbles works great. Just spray on about a can and let sit for about ten minutes. Hose off and then dress the plastic and whatnot
GrizzlyAdams is offline   Reply With Quote
Old 09-26-2012, 04:23 PM   #29
GrizzlyAdams
Member#: 235038
2003 WRX
Scrubbing bubbles works great. Just spray on about a can and let sit for about ten minutes then hose it off. You'll be amazed. No scrubbing needed.
Old 09-27-2012, 03:25 PM   #30
jshutterbug
Member#: 329660
Default Hosing off engine
If you hose off the engine, what areas should you avoid? Are there parts you shouldn't spray that would damage electrical parts?
jshutterbug is offline   Reply With Quote
Old 09-27-2012, 03:42 PM   #31
Esmaee1
Member#: 333492
Pressure wash/armor all or tire shine works like a charm for myself
Esmaee1 is offline   Reply With Quote
Old 09-28-2012, 07:51 AM   #32
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Worst method ever. Armor all will dry stuff out very quickly. Pressure wash? Why would you blast water into an engine bay? Just asking for trouble...
Old 09-28-2012, 07:53 AM   #33
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
http://forums.nasioc.com/forums/show...rubbing+bubble
Read this thread I started a while ago. Somewhere between pages 2-7 is an explanation on what to cover etc.
As for you, read this too.
Old 09-28-2012, 11:22 AM   #34
wrxtuner25
Member#: 260479
2010 WRX
I have been detailing cars for years and the best stuff to use is gunk engine degreaser. I wouldn't use anything else but products that are made to degrease engine bays. Simple green is a very good product as well but you will have to scrub the engine bay a lot more. I would recommend also running the engine for a little while to make sure it is warm before you hose it down. I always run the engine while I am hosing the car down because it keeps the engine hot and the water dries quick so it doesn't cause possible damage to your electrical system. I have seen people hose down cold engines and you sometimes run in to a problem with it starting so I recommend doing this while the engine is warm. Be sure not to spray water to close to your intake as well. Once the engine is dry the stuff I use is called CD-2 engine bay dressing which works the best. It's specifically made to spray on your engine bay and you don't have to worry about wrecking any plastic parts as it is made for this. Hope this helps anybody trying to clean their engine bay safely.
wrxtuner25 is offline   Reply With Quote
Old 09-28-2012, 01:37 PM   #35
built4rally
Member#: 276647
92 SVX LS
Pearl white
super purple degreaser and a pressure washer.
built4rally is offline   Reply With Quote
Old 09-28-2012, 01:42 PM   #36
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
I don't let water pressure anywhere near my engine bay. If Im using pressurized water I hold it a good 5 foot away. Using the pressure itself is asking for trouble
ColeBerkenbile is offline   Reply With Quote
Old 09-28-2012, 02:54 PM   #37
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
Originally Posted by brendan114 View Post
I use P21S TAW to clean engine bays and works great and then use a detailing brush to reach the hard to reach areas. You should cover up your intake with a plastic bag and rinse away with a mister filled with water
+1 for p21s total auto wash. stuff is amazing.
woody06967 is offline   Reply With Quote
Old 09-30-2012, 06:02 AM   #38
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
A lot of the products I see mentioned will discolor or leave spots on your black plastic and rubber parts.
I have only found two products that don't discolor rubber/plastic parts and one isn't made anymore...the one available is from a high end compny called Griots Garage.
Here is a link to their engine cleaner: http://www.griotsgarage.com/product/...,+35+ounces.do
They also make an engine bay dressing as well.
garzdos is offline   Reply With Quote
Old 09-30-2012, 08:32 AM   #39
TehFulg
Member#: 333035
04 WRX GD
I use black magic 2 in 1 engine shine it seems to do the trick im at 100k miles and its still pretty clean.
TehFulg is offline   Reply With Quote
Old 09-30-2012, 08:45 AM   #40
SpeedIsLife
Member#: 333567
2005 WRX Wagon
WR Blue
This is awesome about the Scrubbing Bubbles. I think I might have to go try that.
I have tried Simple Green too, and one of my good friends will use nothing else on his engine.
My 2 cents on cleaning products is this: the greater the risk they pose to your health the better/faster they work. Which is unfortunate, but hey.
SpeedIsLife is offline   Reply With Quote
Old 09-30-2012, 09:02 AM   #41
ironmb
Member#: 333736
Simple green is freaking strong.
ironmb is offline   Reply With Quote
Old 09-30-2012, 02:02 PM   #42
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Why exactly does Armor All contain that will "dry stuff out"? What is occurring to make this happen?
Kean is offline   Reply With Quote
Old 09-30-2012, 02:06 PM   #43
Kean
Member#: 25187
'08 Foz Prem TGM
....if you mean strong smelling, I agree. That's one reason I don't like to use it for this type of application. The other is the potential for accelerated corrosion of bare aluminum if used improperly (i.e. not diluted adequately, allowed to dry or left to dwell too long, etc.). There are aluminum-safe version of their product but there are also many others that perform just as well at this task (if not better).
Old 09-30-2012, 02:33 PM   #44
dewfall
Member#: 123626
2003 WRX
Sonic Yellow
Simple green, Greased Lightening and the like are very good cleaners, but they tend to dull and darken aluminum. I made the mistake of soaking an aluminum part in a solution of it once and it ruined the part. If your intake is painted though, it might be okay.
dewfall is offline   Reply With Quote
Old 09-30-2012, 02:37 PM   #45
dewfall
Member#: 123626
2003 WRX
Sonic Yellow
Griots garage is so high priced. I think it's for the executive, weekend gear head wannabe.
Old 09-30-2012, 10:09 PM   #46
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
Simple Green and/or Scrubbing Bubbles.
WRXGOBerserk is offline   Reply With Quote
Old 10-01-2012, 01:03 AM   #47
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
I think saying someone using this product is a "wannabe" is a little strong...I was simply sharing a product I found that does a good job and doesn't seem to do any cosmetic damage to your engine parts. While I am not of the mindset that things need to be expensive to work well, in this case it is a product I found that works well. It also works great in wheel wells and isn't harmful to your car's finish should any get on it...
And while it isn't cheap, I've found that I need to use very little so in the end I think the cost is likely the same as cheaper products.
Old 10-29-2012, 10:01 PM   #48
iSTI
Member#: 241769
thanks for the link i need to do this to my baby she's been neglected under the hood. lol
iSTI is offline   Reply With Quote
Old 10-30-2012, 02:56 AM   #49
zoli21
Member#: 273536
gunk engine foam works awesome
zoli21 is offline   Reply With Quote
Old 10-30-2012, 10:07 AM   #50
Talon4ever
Member#: 201329
2004 WRX
I second using a diluted mixture of simple green and then following up with the CD-2 engine bay dressing. That is great stuff.
Talon4ever is offline   Reply With Quote
