Old 09-07-2012, 12:40 PM   #1
coopstaloopsta
Member#: 330091
1999 Legacy 2.2
Red
Default 1988 subaru gl 10 Key in ignition and engine doesnt turn over.
When I put my key into the ignition the dash lights turn on and my electrical works. When I turn it more to start the engine nothing happens. It does not attempt to start over nothing at all. The battery is brand new. I have no idea whats going on!!
coopstaloopsta is offline   Reply With Quote
Old 09-07-2012, 07:51 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You have to do some basic testing with a voltmeter or test light to see if the starter is getting power. I'm not sure if your '88 has a clutch interlock switch (assuming manual trans) but if it does make sure it's working. If it's an auto there may be a park/neutral switch.
Old 09-08-2012, 01:10 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Along with Mulder's good advice check the fusible links located in the plastic housing mounted on the coolant reservoir. Check for loose connections.
