Old 09-07-2012, 01:25 PM   #1
skinny_wrx05
Member#: 270662
Default AP Locked My ECU!!!
I just recently purchased a Version 2 AP for my 2005 WRX. Last night I attempted changing maps on my car, only for the AP to tell me that it could not communicate with my car mid-reflash. As a result, it locked my ECU and my car is unable to start. I had my local Subaru shop test all the connections on my car and they came back fine. The AP is married to that ECU and I can`t retrieve any information. I don`t want to try loading up the AP to the new ECU in fears that it will lock the new ECU. Do I send the old AP back for a replacement? And what about the bill for the new ECU? It`s a direct result from the AP.
skinny_wrx05 is offline   Reply With Quote
Old 09-07-2012, 01:53 PM   #2
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Hi there. Sorry for your troubles. I would give your customer service department a call: 866-922-3059
Keep in mind that we do have the capability to recover the ECU in most cases. There may not be a need for a new ECU. Our customer service staff can discuss your options here.
Bill
Old 09-07-2012, 04:39 PM   #3
DabiDa
Member#: 307041
2002 impreza wrx
psm
+1 For Cobb,This happened to me and Cobb had me back on the road in about 4 days.Cobb's customer service is outstanding
DabiDa is offline   Reply With Quote
Old 09-07-2012, 05:05 PM   #4
jebjkey
Member#: 73884
2005 STi
2006 Evolution MR
Lets see if i have this correct:
You had a communications error while you were flashing a map using your AP
You went to a Subaru shop (dealer?) to get it fixed
You bought a new ECU based on their recommendation
You came to NASIOC to find out what you should do now
I do not know what to tell you buddy. Lets try this; here is what you should have done:
You contact Cobb about the issue (or come to NASIOC and get sent to Cobb)
Cobb helps you fix your problem
You move on and be happy
It is doubtful that you needed a new ECU and you definitely should not have bought one before you contacted Cobb for help. Live and learn I guess.
jebjkey is offline   Reply With Quote
Old 09-11-2012, 12:58 PM   #5
insany
Member#: 208652
2006 WRX STI
Does anyone know how to unlock my ECU. It was tuned with AP right before I purchased it. However I have no clue where the tuning company is located and the dealership doesn't recall. So now I'm stuck with my ECU that can only be tuned with AP . Any suggestions would be greatly appreciated. I currently don't have the money to buy an AP, so buying one is out of the question.
insany is offline   Reply With Quote
Old 09-11-2012, 06:31 PM   #6
bacalhau16
Member#: 297565
2011 WRX hatch
Start your own thread as there are a few things to discuss.
bacalhau16 is offline   Reply With Quote
Old 09-12-2012, 12:32 AM   #7
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
How do you know that it is tuned with an AccessPORT? If you are certain and you can find someone in your local area that has a compatible version 2 AccessPORT with your car (there are 3 part numbers SUB-001, SUB-002, SUB-003 that cover different groups of cars), they can temporarily uninstall it from their car, install it to your car, uninstall it from your car and as long as there was an AccessPORT reflash on there (version 1 or 2), then the ECU will be returned to a stock image.
Bill
Old 09-21-2012, 10:00 PM   #8
insany
Member#: 208652
2006 WRX STI
Thank you Bill! It worked like a charm
Old 09-24-2012, 01:34 PM   #9
fitrider82
Member#: 300855
2005 Subaru WRX STi
Hey man, got the $20 you're inbox is full. Good luck with your ECU.
fitrider82 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 06:43 AM.
