Old 11-29-2012, 11:14 AM   #26
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Sorry to revive a dead thread...
For the two wires going to column, can't i just use an ez-tap vs shoving wires into the harness? Was thinking so it doesn't fall out.
Subie FA20 is offline   Reply With Quote
Old 11-29-2012, 11:32 AM   #27
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
2 wires go from relay to relay slot
1 wire goes from relay into the 7.5a fuse
1 wire goes from relay to harness (purple/yellow)
1 wire goes from harness (black- next to purple/yellow) into a ground
Sound right?
This mod will let me run fogs normally, run when stalk is on Fog-ON, and will turn off with car... im.assuming?
Old 12-13-2012, 08:18 PM   #28
p0werline
Member#: 325210
Does this allow the fogs to be on when high beams are turned on?
p0werline is online now   Reply With Quote
Old 12-13-2012, 09:07 PM   #29
S1CkWrx
Member#: 325249
2012 wrx
dgm
Sound right?
did you ever get this to work for you man?
S1CkWrx is offline   Reply With Quote
Old 12-13-2012, 09:39 PM   #30
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
^^^ What he said. I'm also curious about this too.
punkNdrublic04 is offline   Reply With Quote
Old 12-13-2012, 11:05 PM   #31
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Gonna do it again tomorrow. I had it working last time as a quick test but i never actually turned my car on and tried the features of the car running and DRL, Fog, etc. I'll update tomorrow. I made all the wires last time and still have them.
Old 12-14-2012, 02:43 PM   #32
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Did it today. Works awesome! Took about 30 min
Old 12-14-2012, 06:03 PM   #33
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Did you use taps on the column wires?
jester8798 is offline   Reply With Quote
Old 12-14-2012, 06:11 PM   #34
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
Do the fogs stay in with the high beams on?
Old 12-14-2012, 06:59 PM   #35
S1CkWrx
Member#: 325249
2012 wrx
dgm
Do mine haha. Where in NJ are you id pay.
I have the wires and all. PM me
Old 12-14-2012, 07:47 PM   #36
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
I made a quick diagram if anyone needs anything
Old 12-14-2012, 07:52 PM   #37
thescreensavers
Member#: 333820
2013 WRX Limited
Awesome, mod cant wait to do this.
thescreensavers is offline   Reply With Quote
Old 12-20-2012, 12:53 AM   #38
thescreensavers
Member#: 333820
2013 WRX Limited
Did this today, cost me 20 bucks since I did not have the connectors and wires. Though home depot did not have the right wire splices so for now I have a temp solution until I get the correct ones tomorrow but here are some pics.
This is on a 2013
I took off the steel reinforcement bar to gain better access, this picture has it removed you should see it when you take yours off. It just has two 10mm Bolts
This picture also has the Relay Removed and Stalk's Harness Disconnected.
I also completely removed the Dash trim as well which just pulls out and disconnected the wires to the Dimmer switches.
When you Route wires to the purple/yellow and Ground make sure you have enough slack and no wires bind when you adjust the steering wheel through out its full range of motion.
I also found that the second ground was unnecessary as it worked without it, but I wired for it so I am going to use it.
And Yes Highbeams and Fogs work!
Old 12-20-2012, 08:30 AM   #39
S1CkWrx
Member#: 325249
2012 wrx
dgm
only thing i noticed the Fog light dash light doesnt work when you just have the fogs on standalone
Old 02-05-2013, 09:42 PM   #40
jaxx4k
Member#: 232010
Hummm.... will tackle this !!
jaxx4k is offline   Reply With Quote
Old 02-10-2013, 06:01 PM   #41
W.K.S.
Member#: 314986
Doing this today!!
W.K.S. is offline   Reply With Quote
Old 02-20-2013, 11:31 PM   #42
ans2k
Member#: 315631
2012 Impreza Sport
wow, i might try this on my 2012 impreza. where are y'all putting the relay when you done?
ans2k is offline   Reply With Quote
Old 04-28-2013, 12:07 AM   #43
Steck121
Member#: 296527
2013 STI Hatch
I tried doing this today but I am having some problems. I followed the instructions and diagram exactly but now the fog lights or the running lights won't work. I used 18 gauge wire and checked my ground to a few locations, but to no avail. I did put the parking brake down. Also, there seems to be a noise coming from the engine bay, not sure if this is new.
Any help would really be appreciated. Thanks
Steck121 is offline   Reply With Quote
Old 04-28-2013, 12:22 AM   #44
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
The noise wouldn't have anything to do with that since it's not changing anything except for the power going to the fogs (and tricking it to work)
You checked your ground and no avail? Please be a tad clearer. Where did you ground yours to?
You used vampire clips on the stalk harness? Did it actually make contact?
Check your fuses to see if you accidentally didn't blow them out. Did you connect each relay pin to the appropriate relay slot?
Old 04-28-2013, 01:00 PM   #45
Steck121
Member#: 296527
2013 STI Hatch
I eventually got it figured out. The problem was when I connected the vampire clip to the harness the metal did not cut through the insulation.
Old 05-18-2013, 01:10 PM   #46
Rich9579
Member#: 294163
2011 WRX Limited 5Dr
Obsidian Black Pearl
Done! Works great. As another member has commented before, the fog light indicator on the dash doesn't light up when the fog is used. However, it does light up when the main headlights are used. I did skip connecting the ground wire since it was connecting to a wire that was already a ground on the stalk. It's a good thing the fogs automatically shut off when the key is out.
Anybody have any ideas?
Rich9579 is offline   Reply With Quote
Old 11-06-2013, 02:30 PM   #47
Studmike02
Member#: 220095
'95 MX-5
Double post :P
Studmike02 is offline   Reply With Quote
Old 11-07-2013, 09:58 PM   #48
Studmike02
Member#: 220095
'95 MX-5
Just did it on my 2013
Green Garage by Mjbrownell02, on Flickr
More pictures here: http://forums.nasioc.com/forums/show...&postcount=179
Old 11-07-2013, 10:37 PM   #49
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
I'm curious as to why no one has not just wired the signal wire from the stalk switch directly to the relay. Instead of removing the relay and externally wiring it up with separate power and ground...Challenge accepted.
turbogc8 is offline   Reply With Quote
Old 11-07-2013, 10:53 PM   #50
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
Like so.
You could even go as far as picking up the contacts from the dealership and make it look extremely close to stock. You would then need only two wires, a vamp clamp, two OEM contacts, and a fuse tap.
