Old 09-07-2012, 10:54 PM   #1
simplystockwrx
Member#: 314737
2015 WRX
GBP..13 ZX6R
Default 2011-2012 Intercooler to Throttle body hose question
Yesterday I was cleaning my motor this dude stops by and asked if I had a problem with my '12 WRX? After I told him I had no issues then he went on to say that he owned an '11 WRX with around 12,000 miles that was currently at the dealer getting repaired. He was running a Stage 2 set up of some sort and under boost his "intercooler to throttle body hose" was saturated with oil due to blow by and slipped off enough to cause a decently audible whine and vacuum leak. Dude also said Subaru is aware of this issue and is trying to figure out a work-around but would not warranty. I'm guessing the warranty refusal is from the Stage 2 setup. This is all hear say from someone I don't even know and I'm curious if this has happened to anybody else with a 2009+ WRX? Is this possible? Would an AOS fix this issue if there is such an issue? My car is completely stock and I'm driving back to Cali from WV in a few days and I was thinking about removing my intercooler just to check **** out. Before I do that I thought I'd ask around 1st.
simplystockwrx is offline   Reply With Quote
Old 09-07-2012, 11:20 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
An AOS would definitely help. IIRC, there have been reports of oil still getting into the intercooler and throttle body on stage 2+ WRX/STI's (at least with the Grimmspeed AOS).
RoadKillDMD is offline   Reply With Quote
Old 09-08-2012, 06:19 AM   #3
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
stage 2 cars are known to blow the ic to tb hose. remove the bs "gasket" thats in there and retighten, problem solved. if you are stock you are fine. happens at 19 psi
BigRob74 is offline   Reply With Quote
Old 09-08-2012, 07:00 AM   #4
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Yes this is common. More so on modified cars but can still happen stock. I think the best alternative is either the gimmick or AVO throttle body hoses. They are longer than stock and shouldn't slip off. Also, you can get some Tbolt clamps and tighten those suckers down.
DurtyB is offline   Reply With Quote
Old 09-08-2012, 01:26 PM   #5
Shtbxr255
Member#: 291395
2008 Legacy Spec B
QSM
I work at a subaru dealer, and we have replaced a bunch of these. it seems the oil ruins the bond between the sleeves on the ends and the coupler. All replaced under warranty. It seems more prevalent in 2010+ though. I recently replaced on on a car with maybe 500 miles. I'd just replace it with a suitable one piece hose from an aftermarket company if it was my car.
Shtbxr255 is offline   Reply With Quote
Old 09-08-2012, 08:40 PM   #6
guygettnby
Member#: 298231
2011 WRX
I just removed the sleeves on each end of the hose and buttoned it all back up using t-bolt clamps. Problem solved....
Also you can spray abit of hair spray on the inside of the house to help keep it on from what I have read. I didn't bother though since I replaced the clamps.
guygettnby is offline   Reply With Quote
Old 09-08-2012, 08:52 PM   #7
424wrx
Member#: 171948
08 wrx vf52 swap
best et,[email protected]
had the oil issue. installed a grimmspeed aos. no more oil in the tb hose now.i also removed the endcaps on the tb hose. no issues at 22 psi for about 2 years.
424wrx is online now   Reply With Quote
Old 09-08-2012, 09:42 PM   #8
Darkhorse85
Member#: 303734
2012 WRX Hatch
I bet this is the root cause of a lot of the 2011+ WRX all cylinder misfire issues on stock cars with ~10,000K miles.
Anyone have a microfiche diagram or photo identifying the exact throttlebody hose at fault or what the fault looks like?
Darkhorse85 is offline   Reply With Quote
Old 09-08-2012, 10:13 PM   #9
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
this is the "gasket" that needs to go
Old 09-08-2012, 11:02 PM   #10
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Take the "gaskets" or "caps" (shown in the post above) off of BOTH sides of that hose. Then bolt it back on and never worry about it again. I run 27-28psi with the stock hose and it works just fine. No need to spend money on a new one.
xluben is offline   Reply With Quote
Old 09-09-2012, 12:38 AM   #11
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
Moroso AOS is the best out there and is a very nice unit. Actually catches the crap. I have it on my 09 wrx and loooooove it. Get a new aftermarket throttle body hose and two t-bolt clamps and problem solved.
PleiadesSTi is offline   Reply With Quote
Old 09-09-2012, 12:39 AM   #12
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
27-28 psi. Dear Lord son. You got a built motor???
Old 09-09-2012, 01:49 AM   #13
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Oh my..
http://forums.nasioc.com/forums/show....php?t=2078765
Old 04-21-2013, 05:59 PM   #14
crschneiderwrx
Member#: 324337
2011 wrx
satin pearl white
i have a 2011 wrx and the tb to ic hose has popped off multiple times. I installed a grimmspeed aos and it happened again at the track was running 13.3, then a 13.7 then a 14.3!!!! i was like!!! BOOOOOST LEAK!!! didn't think to just get rid of the darn gasket things that make installation a hassle to begin with. I was just going to upgrade to a fms tmic (processwest replica) and replace the darn hose!
crschneiderwrx is offline   Reply With Quote
Old 04-21-2013, 08:35 PM   #15
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Just take the caps off like I suggested. I'm currently on a new setup and I'm still running the stock hose. At around 30psi right now, but I've done pulls up to around 32psi without any issues.
Old 04-22-2013, 01:43 AM   #16
bacalhau16
Member#: 297565
2011 WRX hatch
crschneiderwrx, I hope you already have all the stage 2 supporting mods and such for that upgrade. Spending that much money on a new TMIC when all you have to do is remove the endcaps/gaskets on the stock tube, just seems wasteful.
bacalhau16 is offline   Reply With Quote
Old 04-24-2013, 10:40 AM   #17
nickysigz06sti
Member#: 354054
My 06 still did this two days ago... found myself in auto one parking lot using a spectre hose from auto one to hold up for now.. it seems to be holding good considering I drive my car pretty hard.. im a little more then what most would consider stage two . Anyone heard of this happening to 2006 stis?
nickysigz06sti is offline   Reply With Quote
Old 06-05-2014, 11:17 AM   #18
Mayamar44
Member#: 366921
Default Hose from throttle body to inner cooler
Just had hose from throttle body to inner cooler replaced. 9000 miles on 2012 WRX. It was loose, dealer replaced no dolla under warranty. Also, had driver side turn signal harness rerouted, blinking quickly and owners manual says it's a bulb. Not with 9000 miles on it. No dolla there either, warranty. Even replace rear wiper blade, dealer specific no Pep Boys, no dolla.
Mayamar44 is offline   Reply With Quote
Old 06-05-2014, 06:50 PM   #19
Eyedeas
Member#: 359202
2013 WRX
Tangerine Orange Pearl
I can confirm this.
Eyedeas is offline   Reply With Quote
Old 06-06-2014, 02:38 PM   #20
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If the dealer replaced the hose, that means they put those rubber caps back on the ends. That means that it will probably fail again later and could cause damage to the motor due to a lean condition. The correct resolution would be to remove the caps from the ends of the hose.
Old 06-07-2014, 10:05 AM   #21
Omni003k
Member#: 348963
2008 WRX
Lightning Red
As it has been said, you don't need a new hose, just take off the retarded rubber boots off of the stock hose and re-install it.
Omni003k is offline   Reply With Quote
Old 06-08-2014, 12:20 AM   #22
Eyedeas
Member#: 359202
2013 WRX
For the record, I needed a new hose because the stock one wasn't long enough to comfortably fit on my perrin top mount. So, just saying. Some may benefit from a cheap silicone hose.
I did run stock with no caps for awhile though.
Old 06-29-2014, 01:12 AM   #23
yertle
Member#: 71910
2005 WRB WRX - Stg 2
2013 DGM WRX 5-dr
I was at the track today and the car ('13 WRX stg2) seemed low on power, and I could hear my turbo more than usual. I hadn't been at this track with this car though, so it was tough to tell. AP shows 13.8 max psi but I wasn't sure what my target was (I wasn't super smart today). In my last session the car hesitated and I finally had the sense to call it quits. I checked the hoses more thoroughly and finally found the clamp had slipped off this stupid gasket. Reassembled at the track (with gasket) and drove home.
Am I at risk of having damaged anything? I was at a track so I wasn't taking it easy. I'm hoping that everything was just running rich when it wasn't getting full boost?
I will remove the gaskets and crank down the clamps - thanks for the info.
yertle is offline   Reply With Quote
Old 06-29-2014, 07:49 AM   #24
Jubathoph
Member#: 382959
When you have a leak in the intake tract post compressor, you will run lean while the manifold pressure is in vacuum because unmetered air is getting sucked in through the leak. When you get into boost it will run rich, because metered air is now getting pushed out of the leak.
I struggled with hoses popping off and leaky tb to IC hose when upping the boost to 20psi. You should look at boost pressure and AF learning to troubleshoot small leaks.
Normally my vaccum pressure was -10.3 to -10.5 warmed up vacuum pressure, but with a small leak my vacuum pressure was in the -9 psi range.
Jubathoph is offline   Reply With Quote
Old 06-29-2014, 09:44 AM   #25
mejifair
Member#: 11356
2012 WRX STi Hatch
What was this picture? I am curious to take a look at mine. I took the IC to TB hose off last weekend and it had a little bit of oil in it.
I get a high pitched "psssssst" at WOT ever since installing my TXS catback and I have been looking at different areas to pinpoint the sound.
Thanks.
mejifair is offline   Reply With Quote
