Old 06-12-2013, 04:51 PM   #1
mike_1988
Member#: 226571
Default jdm sti v8 and tactrix cable question
hi was wondering what cable should i use want to start. tuning my car alone . any tactrix work or should i get 1.3 or 2.0
car is a wrx 2002 with sti v8 swap and All drivetrain is sti v 7
thx in advance for the help. im new to this
and sorry for the grammar im french. from quebec city canada
mike_1988 is offline   Reply With Quote
Old 06-12-2013, 04:58 PM   #2
25rsti
Member#: 166324
1.3 or 2.0 should work but if I had the choice I would get the 2.0.
Do you know how to tune? Also, there is a thread in the WRX 2.0 Forum for EJ207 owners.
25rsti is offline   Reply With Quote
Old 06-12-2013, 05:01 PM   #3
mike_1988
Member#: 226571
well to be honnest no i dont but it must be something you start slowly and become better at it. i figured id buy a cable try conecting to it and see if it work think the jdm cpu is locked on ecutek ... if it is the. ill try to find some 1 to unlock or buy an unlocked 1 then read about my log and start adjusting thing . thx for your help again
Old 06-12-2013, 05:50 PM   #4
mike_1988
Member#: 226571
well anyone know if my jdm ecu will be bricked from ecutek i have read. only wrx 02-04. cant be unlocked from ecutek but i presume they talk usdm model jdm could be a whole new world there thanks in advance
Old 06-12-2013, 05:58 PM   #5
25rsti
Member#: 166324
You're right about them being bricked on the usdm ecus. I'm not sure about the jdm ones.
Why do you think your jdm ecu has ecutek on it?
Also, I would NOT start to tinker into tuning/adjusting if you don't know what you're doing. Nothing against you (heck, I have romraider, tactrix 2.0 and wouldn't make adjustments) but you don't want to blow up your motor and or car.
Old 06-12-2013, 06:06 PM   #6
mike_1988
Member#: 226571
well i already tryed. using a tactrix cable that a friend add and failed and tried with hos v8 ecu and worked flawlessly and the swap i bought is from lachute performance here in quebec and that shop seem to alway use ecutek that why i think it is. but now ill buy my cable and try harder myself to see if the laptop or anything else was the trouble. and then i might just data log for couple of month and a lot of reading then ill. try. it myself no worry i wont risk my. good setup on a poor mistake so i wont. be doing thing i dont know im 110% sure and. will ask when the time cone to flash
