#1 |
Member#: 321425
Vehicle:2002 Impreza WRX Aspen White |
Ok, so I bought this car with about 174k miles. It had a knocking noise when I bought it, it turned out being one of the idlers. My mechanic fixed it, and changed the timing belt. I added about 3k miles to it so far, had fun with it. After a long drive, it began making a rattling/scraping noise. I cant figure out what it is. The sound comes from the right camshaft area. Let me know what you guys think it could be. Thanks in advance.
#2 |
Member#: 321425
![]() It looks like it could be an idler that is damaged. The timing belt was changed not to long ago. Found this chip in my timing belt. |
#3 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
I can't tell from the vid but it sounds bad. Take it to your mechanic or bring it by here and I will tell you what it is.
#4 |
Member#: 321425
Yea, Im at college and im looking for a Subaru mechanic up by Ithaca NY.
#5 |
Member#: 331941
Vehicle:2002 WRX Silver |
Hard to tell. Cam bearing?
#6 |
Member#: 321425
Im thinking about just getting a timing belt kit and change all the idlers and belt.
#7 |
Member#: 321425
UPDATE: I got a timing belt kit and changed everything. At first, everything sounded good, but after letting the car sit for a while, the sound returned. This time however it sounds a bit lower and periodical depending on acceleration, and seems to go away when the car is hot. I convinced myself that it is just one of those random Subaru noises since it seems to go away after driving.
#8 |
Member#: 252943
NWIC
Vehicle:2003 wrx sport wagon silver |
How is the alternator barring. My car sounded like that and went away after it warmed up. My issue was the alt barring . Take the alt belt off and spin it
#9 |
Member#: 321425
Thanks for the idea, Ill check it out.
#10 |
Member#: 321425
UPDATE: So its been a few days, and seems like the sound has gone away. Don't really know for sure what it was, but the car sounds better now, and running good.
