Old 09-09-2012, 10:51 AM   #1
ricky0418
Member#: 236866
2013 Charger SRT8
white
Default 2011 wrx ,COBB AP newb please take a look at my datalogs ! thanks
2011 wrx ,COBB AP newb 3rd gear pull ( i tried my best) im running the stage 1 93 octane map from the AP if anyone could pls tell me if everything is ok, only mod is an invidia Q300 catback, THANKS!
https://docs.google.com/spreadsheet/...Fo1ZVM5SUNhOHc
ricky0418 is offline   Reply With Quote
Old 09-09-2012, 12:38 PM   #2
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Change your permissions. We cant look at them.
SouthernWRX is offline   Reply With Quote
Old 09-09-2012, 02:43 PM   #3
ricky0418
Member#: 236866
2013 Charger SRT8
white
i think i unlocked it know! sorry about that
Old 09-09-2012, 03:18 PM   #4
ricky0418
Member#: 236866
2013 Charger SRT8
white
anyone?
Old 09-09-2012, 06:08 PM   #5
ricky0418
Member#: 236866
2013 Charger SRT8
white
Old 09-09-2012, 10:54 PM   #6
ricky0418
Member#: 236866
2013 Charger SRT8
white
Old 09-10-2012, 04:47 AM   #7
kaczmarz
Member#: 307624
2008 WRX Hatch
325/347, 380XT, 8 cm2
Start your runs well above 2000 RPMs to avoid knocking, which retards timing (lowers DAM) which decreases performance (acceleration).
Be very light on throttle when in 3+ gear below 2500 RPM. If you don't believe me, make long data-logs during normal driving to see if you get occasional knocks when stepping in on throttle at lower RPMs.
Other than that everything looks OK.
kaczmarz is offline   Reply With Quote
Old 09-10-2012, 08:15 AM   #8
ricky0418
Member#: 236866
2013 Charger SRT8
white
^^^thank you!
Old 09-10-2012, 09:29 AM   #9
Cobb Tuning
Member#: 4803
Originally Posted by ricky0418 View Post
2011 wrx ,COBB AP newb please take a look at my datalogs ! thanks im using the cobb ap stage 1 93 octane.
https://docs.google.com/spreadsheet/...m9tTXh3NW1fV0E
This is a 3rd gear run? What are all your mods and did you buy the car new? You are underboosting quite a bit.
As kaczmarz stated, you do not want to lug the engine. Start your runs above 2000 RPM.
Bill
Old 09-10-2012, 10:22 AM   #10
ricky0418
Member#: 236866
2013 Charger SRT8
white
thank you , i went too early to 3rd gear, the car i bought it new it has now 10,000 miles, and the only mod is an invidia Q300 catback, i guess ill do another run when i have a chance, do you recommend me switching to the HWG map to fix the underboosting problem?
Old 09-10-2012, 03:33 PM   #11
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill
i did a new datalog , i tried my best but the car goes scary fast on 3rd towards the redline, thanks for the help!
Old 09-10-2012, 03:34 PM   #12
ricky0418
Member#: 236866
2013 Charger SRT8
white
Old 09-10-2012, 11:14 PM   #13
ricky0418
Member#: 236866
2013 Charger SRT8
white
Old 09-11-2012, 09:11 AM   #14
Cobb Tuning
Member#: 4803
You'll need to also set the permissions to public on this log.
Bill
Old 09-11-2012, 09:13 AM   #15
ricky0418
Member#: 236866
2013 Charger SRT8
white
It's public just click on the link
Old 09-11-2012, 09:31 AM   #16
Cobb Tuning
Member#: 4803
Still doesn't work for me - gives the "you need permission to access this item" message.
Bill
Old 09-11-2012, 10:20 AM   #17
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill
i changed to public i hope it works now :/
Old 09-11-2012, 01:45 PM   #18
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill from cobb! i already changed the permissions please take a look at my log
Old 09-12-2012, 01:23 AM   #19
Cobb Tuning
Member#: 4803
You are underboosting a little. You do have a single count of fine knock learning that appears to have been learned during this run. The feedback knock correction is close to the start of your run and is probably noise.
I would get a few more WOT logs - one learned event could just be a fluke.
What octane map are you running? I would make sure you are using a quality gas brand - some people have better luck with the so-called "top tier" gas brands.
Bill
Old 09-12-2012, 10:18 PM   #20
ricky0418
Member#: 236866
2013 Charger SRT8
white
^^^^thank you!
