Old 09-09-2012, 05:37 PM   #1
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Question Why Is My Car Pulling Timing?
Question: What are the possible mechanical reason my car is pulling timing?
Car: 2002 WRX w/4EAT and 160,000 miles
Background: I have had an OTS Stage II map on my car for the past 5 years. When I first flashed it, I did some logs and everything was fine. Recently I started logging it again just to check it and the car was pulling timing from about 4000 RPM. IAM is also reading very low. I changed to some thicker gaskets on the uppipe, thinking that I might have a boost leak. but it was still pulling timing. I also recently began having issues with my Factory Boost Controller, so I replaced it with the Grimspeed BCS and flashed a new OTS map that was specifically for the Grimspeed BCS. It's still pulling timing and IAM dropped from 15 when I started the car to 0 when I did my run.
The car seems to be running pretty good though. I'm not hearing any pinging or ticking, it pulls hard and smooth.
Here is a log I took today.
https://docs.google.com/spreadsheet/...HdESksySEZiQ1E
criscross79 is offline   Reply With Quote
Old 09-09-2012, 05:38 PM   #2
Acrdys
Member#: 152261
2007 WRX 2.5
Crystal Gray Metallic
Check MAF
Acrdys is offline   Reply With Quote
Old 09-09-2012, 05:40 PM   #3
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Originally Posted by Acrdys View Post
Check MAF
I have tried cleaning it, but beyond that I haven't done anything. How can I test it?
Old 09-09-2012, 06:05 PM   #4
Acrdys
Member#: 152261
2007 WRX 2.5
For me, the o-ring that seals it was cracked causing a leak @ high rpm. Check it for leaks. Borrow another fellow subie's MAf and test it on your car. See if problem goes away.
Old 09-09-2012, 06:11 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Yikes! It looks to me to be a post MAF leak or boost leak. How does the inlet look where it connects to the turbo?
BlazeRex is offline   Reply With Quote
Old 09-09-2012, 06:49 PM   #6
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Oh, I forgot to mention that. I replaced the stock intake hose because of a hole in the rubber part that connected to the turbo with an aftermarket one. The car had better throttle and boost response, but was still pulling timing. Earlier today I double checked all the hose clamps to make sure everything was tight and everything still looked good.
One other thing I forgot to mention was, awhile back I accidently stripped out one of the bolt holes that holds the BOV to the intercooler. I re-tapped the hole, but I had to go with a bigger bolt. The new bigger bolt wouldn't go through the gasket, so I just used liquid gasket. I checked for leaks, and there wasn't any. I haven't checked for leaks since then though.
Old 09-09-2012, 06:51 PM   #7
wrx3r
Member#: 117489
You will hear a boost leak from the bpv, sounds like you ran over a pack of squirrel
wrx3r is offline   Reply With Quote
Old 09-09-2012, 06:58 PM   #8
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
lol ...no, I don't hear anything like that
Old 09-09-2012, 07:20 PM   #9
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Try replacing your crank position sensor.
illmatic is offline   Reply With Quote
Old 09-09-2012, 08:36 PM   #10
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Most of the time inlets will need a retune of fueling to get it right.
Look at the AFR's in the run. Although not perfectly accurate, they give you a rough estimate of what its running. Mid 12's. That is very lean. Also, airflow/load look low for 17ish psi.
All this leads me to believe there is a failing MAF or a leak somewhere.
Old 09-09-2012, 08:36 PM   #11
philly15
Member#: 223137
14' super ultimate
race car project
are you running a stock intake system? anything other than a cobb short ram could cause issues
philly15 is offline   Reply With Quote
Old 09-09-2012, 09:20 PM   #12
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
OK, so I inspected and cleaned the MAF, took out the Crank Position Sensor, and reset the ECU. I took it for another spin and I have the log below.
I didn't see anything really on the MAF, it was a little dirty, but not that bad. I did notice a small crack on the thin frame that goes around the brown bulb part, but otherwise, the rubber o-ring was fine. The car would also stall as soon as I disconnect the MAF. I'll see if I can find someone who will let me borrow their MAF though.
The CPS was very dirty, but no scratches or dents. I cleaned it up and put it back in. The car seemed to run a bit smoother afterward.
Here is the log I took. I did notice that the car pull timing until after 6000 rpm, which is higher then normal. Usually it starts pulling 1000rpm sooner.
https://docs.google.com/spreadsheet/...kZBVEVlOUVfUUE
Old 09-09-2012, 09:22 PM   #13
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I'm running the stock box with a Fram Air Hog flat panel filter, minus the scoop under the hood and the silencer.
Old 09-09-2012, 10:02 PM   #14
Acrdys
Member#: 152261
2007 WRX 2.5
Make sure you reset the ecu too if you make a change/fix something/log
Old 09-10-2012, 05:32 AM   #15
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
please double check the green connector as well as flash connector.
to make sure you did not leave either on connected.
if not, thats not good..pulling timing means there is knock..
Old 09-10-2012, 01:30 PM   #16
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I have all that stuff wired up to a switch. The switch is off, so I'm not running in limp mode. I haven't ever disconnected it all though since I I put the switch in 5 years ago
I'm also not hearing any pinging or knocking from the engine either?
Old 09-10-2012, 03:33 PM   #17
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
You are in San Antonio... It's hot. Are you sure it's not pulling timing due to IAT? Where were you when you data logged 5 years ago?
The ecu could be pulling timing due to knock. High IAT, or low octane fuel, can cause levels of knock that are imperceptible to the naked ear. It's normal operation for this to happen.
Bacon117 is offline   Reply With Quote
Old 09-10-2012, 04:23 PM   #18
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I was in Massachusetts last time I logged so temps were a bit cooler... I'll try doing a log early in the morning when it is cool out
Old 09-10-2012, 04:35 PM   #19
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
How old are the spark plugs?
I'd try lowering the timing by a couple of degrees and seeing if that clears it up. I've had many maps that look good at first, but after a period of time, issues will settle out that need to be dealt with.
Brock31 is offline   Reply With Quote
Old 09-10-2012, 04:42 PM   #20
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Why is it a problem that it's pulling spark? This is a normal function. Does your car feel down on power? Is your check engine light on? ALL cars will pull spark at some point. That's why they have knock sensors, and why so much time is spent developing the algorithms to read the knock sensor signals.
Old 09-10-2012, 05:03 PM   #21
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Not 5.5* at WOT! I mean it could be engine noise, but other things as well... That much knock is problematic.
Old 09-10-2012, 05:42 PM   #22
Acrdys
Member#: 152261
2007 WRX 2.5
Any updates? reset the ecu and do the ecu learning trick.
http://forums.nasioc.com/forums/showthread.php?t=302047
do a pull and let us know if it still pulls timing.
Old 09-10-2012, 09:24 PM   #23
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
- Spark plugs are only about 6 months old. They are 1 step colder iridiums.
- I don't have any CEL's
- Since I went to the new map with the EBCS, the car feels sluggish, but on the old stage II map the car felt great!
- I'll take the car out tonight with the cooler air and do a pull or two and post it up here
Old 09-10-2012, 09:30 PM   #24
Haelan
Member#: 151045
2013 Subaru STI
CBP
He'd have stumbling and phantom misfires if the CPS was dirty or bad. These rarely go out--it can be pulled and the metal shavings cleaned from the magnet.
Haelan is offline   Reply With Quote
Old 09-10-2012, 10:34 PM   #25
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Ok .. as requested, here is the new log with cooler (76 degrees) air. I also reset the ecu prior to the run and did the quick-learn trick.
https://docs.google.com/spreadsheet/...203YWlCNXJsYlE
