Old 09-09-2012, 08:31 PM   #1
Darkinsane
Member#: 203365
Default Engine Rebuild Problem
My cousin recently did a rebuild on his engine in a 99 forester. He pulled the engine out himself had it sent in to have the heads done re assembled it and put it back in. He has been having some problems with it.
#1 It starts up just fine but idles fluctuates strangely.
#2 Temp gauge fluctuates unusually fast.
#3 Fuel gauge no longer works.
#4 But the main problem is that the "At Oil Temp" light comes on and flashes, from what I was reading that indicates that the computer needs to be dealt with and to take it to the dealer...
#5 Probably has something to do with the flashing light, but the transmission slams into gear really hard almost as if it is slipping then catches, it will fluctuate wildly between the gears it is really odd.
#6 I noticed there was some sort of sensor/grounding wire that was not re attached but for the life of me I can't figure out where it goes. I was wondering if it had anything to do with that. I took a picture of it below. But other than that most everything appears to be properly re attached.
Darkinsane is offline   Reply With Quote
Old 09-11-2012, 08:47 PM   #2
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
that wire is a ground that bolts to engine and then the connector hooks up to the male end. located on passenger side wheel well area by ABS module
J.Gibbs is offline   Reply With Quote
Old 09-13-2012, 02:24 PM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I'm going to go out on a limb here and ask if he pulled the engine with the torque converter on it....
~Josh~
Message Board Statistics All times are GMT -4. The time now is 09:01 PM.
