Old 09-09-2012, 10:28 PM   #1
Kunk
Member#: 269732
2015 STI
CWP
Default My first datalog - 2011 WRX OTS 93 Stage 1 + SF Intake
Hello. So I did my first datalog on my AP using the Cobb Stage 1+ OTS map. I am currently running that map along with a Cobb SF Intake and a Invidia Q300 catback. I was wanting to see how my stats were looking. I know nothing of what I'm supposed to see. So if you could just take a quick glance and let me know. I appreciate it.
https://docs.google.com/spreadsheet/...DZ3Q29udl9jRWc
Kunk is offline   Reply With Quote
Old 09-10-2012, 08:26 AM   #2
Cobb Tuning
Member#: 4803
A little bit of fine knock learning, but that can just be noise - hard to tell as it wasn't learned right then. Try to get some additional logs. You are also underboosting a bit, but let's look at the additional logs before addressing that. What octane map are you running?
Bill
Old 09-11-2012, 12:15 AM   #3
Kunk
Member#: 269732
2015 STI
CWP
Bill
Thank you Bill for your response. I will get some additional logs within the next day or two. I am currently running the 93 octane map.
Old 09-11-2012, 12:45 PM   #4
Kunk
Member#: 269732
2015 STI
CWP
Old 09-12-2012, 12:28 AM   #5
Cobb Tuning
Member#: 4803
No current knock in those logs - may have just been noise. What was the outside temp when these were taken? Load seems a bit high for a stage 1 WRX, but could be possible. Sometimes when you see this plus negative fuel trims, it means you have a boost leak. I would drive around through a tank of gas without reflashing any maps or resetting the ECU and see if the fuel trims (A/F Learning 1 A,B,C,D) get worse.
Bill
