Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 09-10-2012, 06:49 PM   #1
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Default JDM v8 ECU ROM read issue
Hey guys, about to start my v8 STi swap into 03 WRX. Was trying to pull the map from the new JDM ECU prior to pulling anything from the engine bay... to send it to the tuner. I plugged the new ECU in and connected my Tactrix 1.3. When trying to read the ROM thru ECU flash, getting and error (no matter which MY Impreza I chose), and this is what the ROM says....
[15:19:55.812] Using interface OpenPort 1.3 Subaru TX48H9Oq9b9574d54dcd45b4c557cd6a9ace3407257e6ca7
[15:19:58.828] denso02_bootloader_cmd_start
[15:20:00.062] denso02_bootloader_cmd_start
[15:20:01.296] denso02_bootloader_cmd_start
[15:20:02.531] denso02_bootloader_cmd_start
[15:20:03.765] denso02_bootloader_cmd_start
[15:20:04.218] kernel get version
[15:20:04.546] interface close
ECU# ends with AH581. Any ideas? Thanks for any input!
Torquey is offline   Reply With Quote
Old 09-11-2012, 01:44 PM   #2
azscooby
Member#: 115297
2002 ej207 vf34
Are you sure you are doing the process correctly?
I had the same issue and I was doing the sequence wrong.....
azscooby is offline   Reply With Quote
Old 09-11-2012, 03:53 PM   #3
chappell943
Member#: 297718
2001 V7 Sti Prodrive
Make sure you have the jumper block attached (need to buy), (these are not the green connectors)
chappell943 is offline   Reply With Quote
Old 09-11-2012, 04:57 PM   #4
candamo
Member#: 288732
2003 JDM STi
+1... green connectors + jumper block in order to read/write on the ecu.
candamo is offline   Reply With Quote
Old 09-12-2012, 03:54 AM   #5
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Thanks for the reply guys! Just to clarify, I did have the green connectors plugged into each other... but not the jumper block. Because I thought the instructions said, the jumper block is ONLY needed if I am reflashing the ECU... not when trying read it. Here is what I was going by:
http://www.romraider.com/Documentati...aiderFAQ#toc14
Old 09-12-2012, 12:20 PM   #6
808_wrx
Member#: 256205
i put my flash block in when i did mine. and i think u need to do the steps fast... i did it slow an got the same result did it again faster an it worked
808_wrx is offline   Reply With Quote
Old 09-12-2012, 09:10 PM   #7
chappell943
Member#: 297718
I thought the same for my car but yes you do need the jumper block in order to read the rom on the ecu or write a new one onto it.
Old 09-17-2012, 01:29 AM   #8
D-Rodman
Member#: 110078
2005 92x - 02 wrx
silver 92x-wrb bugeye wag
Jumper block from an accessport should work, correct?
D-Rodman is offline   Reply With Quote
Old 09-17-2012, 03:33 AM   #9
chappell943
Member#: 297718
Yes, will work with no problems as long as the year off the jumper block is right for your car.
Old 09-24-2012, 10:28 PM   #10
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Thanks again for the help guys.... yes I did have to plug in the jumper block, and that did the trick!
