Old 10-15-2012, 02:12 AM   #76
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Originally Posted by OC_Nooby View Post
Yes I still have the STI TMIC.
OK boys, I don't know what to make out of it....
So then I decided to wire the flap shut (maybe the back pressure was opening the wastegate), nope still 22psi.
OP wants 24psi on a stock TMIC
I really could not believe what I was reading! If you think for 1 god damn second that you have ANY other issue for not hitting 24 psi. Then you sir are living up to your screen name. Not only that, but if you think a stock TMIC is efficient enough for a GT30 size turbo, you have literally got to be one of the most ignorant people on this forum!
Op, I dont know how else to put it other than this.... Get a big TMIC or a FMIC! NOW! and stop what you are doing! You WILL blow this engine to pieces using a stock intercooler! The thing was made for a tiny VF39, how in gods name do you think its fine for a GT30????
uhhhhhh, the stupidity in this thread has me raging!
P.s Leave the wastgate ALONE! there is nothing wrong with it, and NEVER EVER wire it shut!!
UK-Wagon is offline   Reply With Quote
Old 10-15-2012, 02:23 AM   #77
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
You stay classy, NASIOC.
Old 10-15-2012, 02:28 AM   #78
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Oh, and you do realize the wastgate opening at any time after 14psi is normal. Ever thought of EWG's?? They open at spring pressure.... to relieve excess pressure that can cause over boosting. Ive got a 38mm EWG on my car currently that is set at 14psi. At exactly 14 psi it opens but I run 19psi. It was tuned for 22 but we brought it back down. I still ran 22 psi with no issues
The wastegate will open, thats normal, a tiny little leak before 14psi from it also is NOT going to hurt. Many people run 8psi springs on a 24psi set. Im guessing you are under the impression that the WG opens at 22psi or at 24psi. Thats not how it works....
Get a intercooler that is efficient enough to do what you are doing, not only that but a stock TMIC can not efficiently cool the incoming air of a GT30 turbo. YOU WILL blow this engine up if you continue to do what you are doing.
Old 10-15-2012, 02:36 AM   #79
OC_Nooby
Member#: 311781
2003 WRX w STI V8
-I run Meth, I appreciate your concern.
-I'm aware the STI TMIC was ment for a VF39 + other STI turbo's.
-I know its not an efficient Intercooler, FMIC is the way to go.
-Wiring the Wastegate shut should yield me infinite boost. The fact that its not is not right. I did this for ****ing test purposes.
-I understand how a Wastegate works.
-This wastegate opens at 12 psi if left without a MBC.
UK-Wagon, don't be a douchebag. Don't jump to conclusions. If your going to read certain lines then yes, I'm pretty retarded. If you took your time, I tried explaining the steps I took to try to figure this out.
At the end of the day, if a new tmic or fmic will yield me the possibility of going above 22 psi then I'll upgrade. I don't think this is my issue. I'm sure I'm restricting the turbo somewhat but not to 22 psi limit. Again, yes the TMIC is not very good at cooling the air down, my meth kit does a wonderful job though.
OC_Nooby is offline   Reply With Quote
Old 10-15-2012, 02:42 AM   #80
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
-I know its not an efficient Intercooler.
Then why install a GT30 turbo and still use it expecting good results?????
Op, are you Trollin? Im beginning to think you are, and if so... you won, I lost hard! LOL
Old 10-15-2012, 02:52 AM   #81
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Originally Posted by NSFW View Post
That is suspicious, I agree.
Try sending those pics to ATP, see what they have to say...
Will do, I'm curious to see what they say.
Old 10-15-2012, 05:18 PM   #82
OC_Nooby
Member#: 311781
2003 WRX w STI V8
ATP says the STI intercooler is not the problem. I also did a pre intercooler boost test and it came out to about 22psi.
Old 10-15-2012, 05:47 PM   #83
NSFW
Member#: 140444
05 Stage Free LGT
Yeah but what would ATP know, it's not like they built the turbo or.... oh wait, yes they did.
And if the TMIC was the problem then you'd see more pressure upstream of it than downstream of it. Same pressure on both sides means that it's not causing a measurable pressure drop.
Small TMIC + meth seems like a reasonable thing to try, in terms of overall charge cooling. When the boost issue gets sorted out, we'll have to compare logs to see what the pros and cons are of your TMIC+meth vs. my FMIC without meth.
Old 10-15-2012, 05:57 PM   #84
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Sure!
Just waiting on ATP before I try the ultimate test.
Gone to do the ultimate test.
Old 10-15-2012, 06:58 PM   #85
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Took the inlet off (completely). Went for a run. The ****ing car has balls!
So the inlet is robbing me of everything that's power related!
God it hauled ass. 25psi no problem in first gear. So much torque!
Time to make my AMR inlet work. Lots of work ahead of me.
Old 10-15-2012, 07:55 PM   #86
NSFW
Member#: 140444
05 Stage Free LGT
Interesting, I would not have guessed it mattered that much. Which inlet were you using?
Also, are you running blow-through MAF, or SD, or what?
Old 10-15-2012, 08:19 PM   #87
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Using the stock 2.4" inlet (I believe I stated that earlier). Running a MAF, I had to unplug her for the test.
Old 10-15-2012, 09:16 PM   #88
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
that is pretty interesting...i haven't had any issues like this when tuning a larger turbo with 2.4" inlet setup, but then again, they have ALL been aftermarket silicon inlets with aftermarket intakes so...maybe the non-smoothed path of the stock inlet and intake and the fact that it is 2.4" are compounding together. this is a pretty interesting and very helpful find for future reference.
amalgrover is offline   Reply With Quote
Old 10-15-2012, 10:16 PM   #89
OC_Nooby
Member#: 311781
2003 WRX w STI V8
It definitely felt aggressive. Went from 18 psi in first gear to 24 psi. Sucks that the inlet is going to be a pain in the ass to install (header/up-pipe shifted the turbo to the left by half an inch). Ohh Well, Gotta figure it out!
Old 10-16-2012, 11:15 AM   #90
WRteXan
Member#: 223894
What did your turbo inlet look like when you removed it? Was it kinked somewhere in the middle... like maybe it had been sucked in on itself? I would have a hard time believing the 2.4" inlet was that much of a restriction. Not disagreeing its a restriction, just not that much of one.
WRteXan is offline   Reply With Quote
Old 10-16-2012, 12:47 PM   #91
OC_Nooby
Member#: 311781
2003 WRX w STI V8
No the turbo inlet was not kinked. It looks normal.
I'll make a log from a 1st to 4th gear pull with the stocker then with the 3" inlet. I have to put the stocker on first as the uppipe needs to be slightly modified to help me allign the 3" inlet.
Old 10-21-2012, 01:03 AM   #92
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Well, after a full day working on the car, modifying the up-pipe so that the AMR inlet fit nicely on the turbo, welding, bs, yelling, more bs etc it was done.
We had to modify the dp and didn't have any J-bends to complete it so we ran an it open. Car sounded awesome
Went for a spin, wastegate unplugged and the car only made 22psi in 1st to 4th then 25 psi in 5th. It was definitely better then the stock inlet which would have been 18 psi in first, 20 psi in 2nd, then 22 psi 3rd to 5th. So yes an improvement though not as good as the 25 psi I got in 1st without any inlet on the turbo.
I wasn't driving the car but it seemed to have more go for sure (with 3 people). I removed the stock filter and gained about 0.7 - 1 psi in each gear, did this just to make sure that wasn't the restriction.
I'll see what ATP says about this (they say the STI TMIC is not a restriction, just not efficient). I don't have any more money to fab a FMIC so I'll make due till summer. This is plenty of power for winter time, I'll try my BOV to see if the BPV is leaking to rule that out.
When I get the car on Tuesday with the Fabbed up exhaust I'll record a 2nd to 3rd gear pull to compare against the 2.4" inlet.
Old 10-22-2012, 12:31 PM   #93
OC_Nooby
Member#: 311781
2003 WRX w STI V8
BOV helped, I can do 1.7 bar in first gear and get it to 2 bars afterwards. So it was a mix of problems. The inlet helped it breathe and the BPV I guess was slightly leaking? I dunno. Leave it at that.
Old 03-04-2013, 08:16 PM   #94
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Sub'd
imma_stocker is offline   Reply With Quote
