Old 09-10-2012, 07:51 PM   #1
Rodrigohc
Member#: 294042
Default 03 wrx morette
I just got these morettes with hids installed, it took a while for me and a buddy of mine to figure this out ( sort of lol) we got the low beans to work but now my high beans won't turn on, my fog lights don't work either, and the high bean light indicator stays on on my dash all the time!!!! I know this has happen to other people out there, can anyone help me figuring this out with some diagrams or just tell me how ? Please
Rodrigohc is offline   Reply With Quote
Old 09-10-2012, 09:33 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
My guess is the switched ground circuit; with halogens, as long as high and low gets 1 ground & 1 power, it doesn't care which one goes to which. With the ballast for the HID, there should be at least 2 possible repinning combinations of the connector. The correct one shouldn't give you that trouble.
satrya is offline   Reply With Quote
Old 09-11-2012, 09:18 AM   #3
Rodrigohc
Member#: 294042
I'll give it a try!! Thanks for the info
Old 09-11-2012, 10:06 AM   #4
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Np. Test it out with a voltmeter or multimeter. Take one oem connector that would've connected to the oem headlight low/high bulbs, and then test which ones give you a +13V or so. If you get negative, then just switch the voltmeter leads. You should get something like this:
Then, you know which ones to feed your ballast and halogen high beam bulbs with for sure.
Old 09-11-2012, 10:41 AM   #5
Rodrigohc
Member#: 294042
Thanks to you too for the info!!
