South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-10-2012, 10:06 PM   #1
chickenwingo
Member#: 167624
2007 wrx
black
Default Emissions question
Hey guys I am up for emissions testing and had a couple questions. I bought my car a few years back and it came with a catless downpipe already installed. I am throwing codes p0442 and p2096 which I assume are both exhaust related. I am just wondering what my best options are for passing emissions in Arizona. Should I just get a stock exhaust and replace it or are there other options available. Thanks guys!
chickenwingo is offline   Reply With Quote
Old 09-10-2012, 10:13 PM   #2
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Idk the Arizona law... HOW EVER. Alot of people slip on a stock exhaust for the test and then put back their aftermarket after the test.
Navendra94 is offline   Reply With Quote
Old 09-11-2012, 04:09 AM   #3
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
You will not pass emissions if you have a CEL. Don't quote me on this, but after a quick search of the codes, it looks like the first one is a leak in the EVAP system and the second one is a lean code from the rear O2 sensor. Not much help, but good luck.
FastS2k is offline   Reply With Quote
Old 09-11-2012, 12:49 PM   #4
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
It's super easy to pass emissions out here. Just get the codes cleared by your tuner or someone that will do it for you if you don't have the tools to do so.
And like S2k said the evap leak you should just fix anyways instead of clearing that one. But get the rear O2 code cleared and you will be golden.
02blkwagn19 is offline   Reply With Quote
Old 09-11-2012, 01:17 PM   #5
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
what about a cracked windshield?
03.dub.r.x is offline   Reply With Quote
Old 09-11-2012, 01:23 PM   #6
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
we dont have a regular "inspection" out here, they are only interested in emissions equipemnt.
The only time a cracked windshield would matter is if you were getting an inspection for a restored salvage title, at which point the car would have to have been totalled by an insurance company.
bobturismo is offline   Reply With Quote
Old 09-11-2012, 01:33 PM   #7
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
thank you for the update ill probably go thursday lol ive been slacking due to my windshield
Old 09-11-2012, 02:33 PM   #8
bobturismo
Member#: 42145
6-4 jockin da bish-
as long as you don't have any check engine lights stored in the system, you should be good.
Old 09-11-2012, 06:17 PM   #9
chickenwingo
Member#: 167624
2007 wrx
black
Thanks for the help guys i'll look into getting the codes cleared. If that doesn't work ill just do the swap. My windshield also has a huge crack I was worried about that too, glad you brought that up!
Edit: Is getting the codes cleared something an autozone could do, it does it require a special code reader?
Old 09-11-2012, 09:08 PM   #10
2012WRXY
Member#: 316057
2012 WRX
If auto zone clears your codes they will most likely come back after a drive cycle, and a evap leak is not a code you just wan't to clear.
2012WRXY is offline   Reply With Quote
Old 09-13-2012, 04:09 PM   #11
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
woooo pass
Old 09-13-2012, 10:48 PM   #12
bobturismo
Member#: 42145
6-4 jockin da bish-
They usually won't clear the codes for liability reasons I guess, but 98% of the codes scanners do. Also you can rent the scanner from them, clear the code and return and get 100% of you money, same with checkers.
You can reset your ecu by disconnecting the battery for a minute or two, but then it has to go through the drive cycles until it's "ready". If you were to disconnect the battery in line for emissions and then try to go through, it will come up as "not ready".
Old 09-14-2012, 11:48 PM   #13
FastS2k
Member#: 59577
04 fxt notansti
Yeah, generally the autoparts store won't clear the codes. Depending where you live, I have a code reader and can delete the codes for you if you just want to see what happens. Odds are though, they will come back and when you delete the codes the ECU still has to relearn.
