#1 |
Member#: 328622
Vehicle:1999 Impreza 2.5 RS Aspen White |
Does my 1999 2.5 rs have a transfer case or no? This is regarding my problem that I'm having with the wheels binding and popping when making slow parking lot turns in either direction.
I've been hearing so many different possibilites of what could be causing it, so I just took it to a newly discovered "Subaru Specialist" shop 3 min away from my house, and when telling the guy the problem, he was like yup yup, that's the transfer case. I was saying, but wait...isn't it the center diff? in particular the viscious coupling inside the diff? and he kept reinforcing and getting frustrated that I wasn't understanding. He was saying "IT IS NOT PART OF THE CENTER DIFF, THE TRANSFER CASE IS CAUSING THE PROBLEM AND NOT THE CENTER DIFF. my problem is, i've been reading that these subarus don't even have transfer cases...is that true? I went to the shop positive that he'd be like yup it's exactly what you said, but instead he threw a curveball and negated everything I thought and heard from you guys here on nasioc
#2 |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
No, you are correct in that saying that you have a viscous coupling.
#3 |
Member#: 82648
W. Canada
Vehicle:2005 Impreza 2.5 RS Black |
http://www.subaruforester.org/vbulle...ce-them-46979/. All the info u need.
#4 |
Member#: 82648
W. Canada
Got it figured?
#5 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
it has what subaru calls a "transfer case", but that part is not the problem. The viscous coupling inside the center diff is almost certainly the problem. if a shop replaces anything beside the center diff and the bearing I would be very suspicious.
anyone who says "subaru's dont have a transfer case" is both right and wrong, and has never read a subaru FSM or parts book because they call the center diff housing a "transfer case". However, subaru's dont have a transfer case that is like most other 4x4/AWD vehicles drivelines. |
#6 |
Member#: 328622
#7 | |
Member#: 328622
