Old 09-30-2012, 12:11 AM   #126
Haelan
Member#: 151045
2013 Subaru STI
CBP
Great thread. I've got an inexpensive thermal gun and this makes it look like a toy. I purchased a turbo blanket for my former WRX, but never installed it. Had I seen these results it would have been on the turbo the day it arrived in the mail.
Kudos OP.
Haelan is offline   Reply With Quote
Old 09-30-2012, 01:34 AM   #127
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Originally Posted by the suicidal eggroll View Post
I guess you've never heard of vibration?
to the point of wearing through the blanket fibers when there arent any sharp edges on the underside of the heat shield?
HeroCrank is offline   Reply With Quote
Old 09-30-2012, 12:56 PM   #128
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Originally Posted by HeroCrank View Post
refer to PTP's website in the FAQ section or a thread that the Unabomber made here. There are no negative effects of running a turbo blanket.
I've been using a P2P turbo blanket for a long time now and I've had 2 issues with turbo blankets in general (rather than P2P).
First, on an upgraded turbo in my Scooby with IWG and a T3/T4 sized blanket I have experienced interference with WGA operation. Even when adequately fastening the blanket with mechanic's wire and verifying clearance I have come back a month later and found it rubbing and WGA action to be hampered.
Second, my Ford developed a leak on the turbo oil supply fitting. The inside of the turbo blanket was saturated with oil and it was only a matter of luck and timing that it didn't burn to the ground. Anything that collects, contains and wicks a significant amount of oil in the immediate vicinity of a turbo hot side is a big liability.
Can you capture infrared images when the turbo, intercooler, etc. are actually in operational heat ranges? I am curious to see the data at driving temperatures. Maybe do some 60' launches in the parking lot or use fuel cut launch control to get everything hot? Or just flog the car on the highway and pull over immediately.
Thank you sir, well done.
Mike Costin is offline   Reply With Quote
Old 10-01-2012, 10:05 PM   #129
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
here are some pics after some aggressive driving. My blanket moved a bit and some of the turbo is exposed and the infrared picks it up nicely.
here is a pic of the downpipe
as you can see quite the difference once you apply boost.
Old 10-01-2012, 10:09 PM   #130
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
there was a question back a few about, how much heat was being trapped under the blanket? well, as you can see 470 F is underneath and about 100 and change is getting through, with less on the top of the heatshield.
Old 10-01-2012, 10:13 PM   #131
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
TMIC after the driving
was idling for a bit so it got heatsoaked a bit while i took the other pics.
Old 10-01-2012, 10:14 PM   #132
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Dammit you might talk me into getting a heat shield as well. I'm going cheap though and doing the Bomber's DIY kit with a buddy. Blanket for $18.50? YES PLEASE.
I'm surprised the composite is getting that hot.
So when you throwing on a PW or FMS TMIC?
Mike 01Hawk is offline   Reply With Quote
Old 10-01-2012, 10:17 PM   #133
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Old 10-01-2012, 10:24 PM   #134
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
more downpipe action after a few mins of cooling.
**I have also obtained 100 ft of PTP's lava wrap for my downpipe, so when I get some time soon ill be adding that update as well.**
Old 10-01-2012, 10:31 PM   #135
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
send me a copy of your DIY blanket if you want it tested.
Old 10-01-2012, 11:45 PM   #136
gtasti
Member#: 152036
2004 Sti
Great info hero thxs
gtasti is offline   Reply With Quote
Old 10-02-2012, 02:17 PM   #137
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Excellent! Thank you sir
Old 10-10-2012, 05:14 PM   #138
RIBahler
Member#: 326537
2005 WRX STi Wagon
Crystal Grey Metallic
Now I feel good about spending the extra cash on the heat blanket! Great work!
RIBahler is offline   Reply With Quote
Old 10-11-2012, 11:59 AM   #139
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Great job Hero! Where's those lava wrap pictures?
slowgenius is offline   Reply With Quote
Old 10-11-2012, 09:02 PM   #140
Jimmy P
Member#: 297302
2006 WRX
Very cool thread!
Jimmy P is offline   Reply With Quote
Old 10-11-2012, 10:01 PM   #141
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
the infrared testing is nearly complete, this weekend I would expect an update.
Old 10-12-2012, 01:13 AM   #142
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
your DP isn't wrapped, right? i'd like to see an reading with a wrapped DP
A Fatal Ode is offline   Reply With Quote
Old 10-12-2012, 01:56 AM   #143
MRF22
Member#: 210516
2005 Sti
AW
Originally Posted by scoobyboobys
Thank you.
MRF22 is offline   Reply With Quote
Old 10-15-2012, 09:11 PM   #144
hutch959
Member#: 267463
i installed my ptp blanket and wrapped my downpipe this weekend. I also left the cobb heatshield on for the extra heat protection.
initial results... opening the hood after a decent run there is a noticible difference. the intercooler is barely warm to the touch and just the heat around the turbo is no where near as hot as it usually is. I could touch the heat shield with my hand.
very nice.
hutch959 is offline   Reply With Quote
Old 10-15-2012, 09:48 PM   #145
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
very nice.
hey congratulations! welcome to the club
Old 10-16-2012, 08:30 AM   #146
Redmed427
Member#: 254409
2011 WRX 5-door
LR
Am I the only that didn't notice much of a difference? No way in hell I'd be able to touch the blanket, or heatshield with my bare hands after a run. Surface temps were 350 degrees on the blanket and 180 on the heatshield.
Did I do something wrong?!
Redmed427 is offline   Reply With Quote
Old 10-16-2012, 08:50 AM   #147
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Quick question: can you benefit from a heatshield/turbo blanket without needing a retune?
mrkyle3 is offline   Reply With Quote
Old 10-16-2012, 09:04 AM   #148
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Yes.5
Psychoreo is offline   Reply With Quote
Old 10-16-2012, 09:25 PM   #149
hutch959
Member#: 267463
hummm... around 65 degrees here.... but a drive from work to home with a little spirited driving up a mountain, i could touch the heat sheild. Not place my hand on it and leave it there, but i could touch it without being burned. before, i could feel the heat on my face when i looked at it.
I got the blanket really tight around the hot side...
it made a noticible difference.
Old 10-16-2012, 10:11 PM   #150
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
take a pic of your install, maybe we can help
