Old 09-11-2012, 08:03 PM   #1
Yakattak
Member#: 284332
2003 Impreza WRX
Platinum Silver Metallic
Default Front tires leaking
I recently had my tires rotated, and ever since the rotation (although I may have not noticed it before when they were on the rear) that my two front tires lose air like nobodies business. I filled them up like a week, week and a half ago and when I went to check them today they were about 7 psi under spec. Does anyone know what could have caused this? I'm like a month and a half away from snow tires, then after the winter season I'm picking up new summer tires and wheels I just don't want it to happen with my snow tires as well.
Yakattak is offline   Reply With Quote
Old 09-11-2012, 09:58 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Apparently, air is leaking out somewhere. It must be coming through some sort of gap or opening where the wheel/tire assembly is not air tight.
Old 09-11-2012, 10:34 PM   #3
Yakattak
Member#: 284332
2003 Impreza WRX
But what are the odds that it's BOTH tires?
Old 09-13-2012, 08:02 PM   #4
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
The tires are old correct and probably done. Rotating would have nothing to do with it. Unless your wheels have a bend or crack, make sure to look, as tey can be small.
Ernest is offline   Reply With Quote
Old 09-13-2012, 08:05 PM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Psychoreo is offline   Reply With Quote
Old 09-13-2012, 08:28 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
When u get new tires make sure they instal new valve stems cuz this could be the issue or the tires r just worn and not seating properly on the rim of your wheels.
trev762 is offline   Reply With Quote
Old 09-13-2012, 10:11 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Since pressure is dropping in both of them, apparently the odds are pretty good that both could have a leak.
There's really not much (not anything?) that we can do to find a leak through the internet.
Old 09-14-2012, 02:44 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the tire place may have loosened the valve cores in an attempt to make you come back to get them replaced
seen this done in the past
