Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-12-2012, 08:39 AM   #1
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Default bulb shuts off
I retrofitted a set of jdm headlights with tsx projectors. I used Conway ballast and ds2 bulbs. I had a harness made for me with relay and fuse from light modz. Worked fine for a couple weeks. One night one bulb turned off. If I cycle the lights off then on, it came back on for a little while. I switched the ballast to see if that is the problem. Same light goes out as before.
So can a bulb be bad and still somewhat work? I read the FAQ and am wondering if i have a ground issue. In the meantime switch bulb sides and see if the out light follows the bulb?
Stays on about 10 min...
maxpowr is offline   Reply With Quote
