Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 05-07-2013, 07:08 PM   #251
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
Originally Posted by ImprezaWrx9 View Post
I think it is off by a couple of MPH. I'll take another one at 288,888
make sure you are going 88mph when you take the pic
bugeye829 is offline   Reply With Quote
Old 05-08-2013, 01:52 AM   #252
Steye05
Member#: 197008
2013 WRX
Plasma Blue Pearl
2003 Sonic Yellow WRX. Stage 2 194,xxx. Stock intercooler, stock td04 and running good numbers for the setup and miles
Steye05 is offline   Reply With Quote
Old 05-08-2013, 10:31 AM   #253
SnowBRDGod247
Member#: 319756
2002 Audi S4
Very nice!
SnowBRDGod247 is offline   Reply With Quote
Old 05-08-2013, 01:55 PM   #254
master_o_trunks
Member#: 328158
Awesome read
master_o_trunks is offline   Reply With Quote
Old 05-09-2013, 03:40 AM   #255
myschims
Member#: 355688
Not a wrx but the forester I just picked up has 280k on it
myschims is offline   Reply With Quote
Old 05-09-2013, 09:49 AM   #256
SnowBRDGod247
Member#: 319756
2002 Audi S4
Lol! We will accept that I love foresters too
Old 05-31-2013, 06:07 PM   #257
MyOtherRideIsUrMom
Member#: 159636
2007 WRX WRB-18G EWG
2014 Outback LTD ISM
2007 WRX bought new in 9/07, 18g since 5000 miles, bunch of other stuff added since then (ewg, fmic, fueling, suspension, etc). Replaced clutch/pp/fw/tob at 175k, but didn't need to be done. Stock engine internals, just clicked over 200k!
Only recent photo I have:
MyOtherRideIsUrMom is offline   Reply With Quote
Old 05-31-2013, 07:31 PM   #258
some dude
Member#: 100300
06 WRX
CGM
^ very nice 07'. Especially considering 18g'd basically it's whole life. What gear are you in, in that picture?
some dude is offline   Reply With Quote
Old 05-31-2013, 07:56 PM   #259
MyOtherRideIsUrMom
Member#: 159636
Thanks. Im assuming you are talking suspension? if so it sits on Cusco Zero-2E's in summer, stock suspension in winter.
Wall-O-Text Somewhat complete mod list
FP TD05-18GH
Coated hotside
Intake:
APS WRX-FMI/R6 -
APS DR525 FMIC (Black)
APS WRX-HFA/01 -APS 65MM CAI
APS HIGH-VOLUME DUAL VENT BOV
Perrin MAF highflow tube
Agency Power Cast turbo inlet
Grimmspeed 3mm intake spacers
Engine Management:
Cobb Accessport V2
Cobb AccessPort FP18G 93 Map
Clark Turner 93 Octane FP18G map
Engine:
Deatschwerks 850cc injectors
Agency Power Fuel Rail
Killer-B oil pickup
Exhaust:
APS 3" Single Outlet, Turbo Back Exhaust
APS 3" High Flow Cat
Kartboy XL exhaust hangers
Grimmspeed 44mm External Wastegate uppipe
Grimmspeed Ported & coated exhaust manifolds
Grimmspeed manifold cross pipe
All exhaust wrapped with Thermo Tec Copper wrap w/spray
Tial 44mm v-band external wastegate w/ 1 bar spring(s)
Suspension:
Cusco Zero-2E Coilover Kit
ECON Controller for coilovers
Whiteline adjustable front & rear strut brace
Hotchkis Rear Endlinks
Kartboy Front Endlinks
Energy Suspension Front Control arm bushings
Energy Suspension Rear trailing arm bushing
Perrin Adjustable F&R 22mm Sway Bars
Transmission:
Cobb Double Adjustable Short Throw Shifter
Cobb hardened shift bushings
GReddy Counterweight Shift Knob
Kartboy Rear Shifter bushing
Whiteline Transmission bushings
Group-N Transmission Mount
Audio:
190+Ft/Sq Dynamat Xtreme
24FT/sq Tac Mat
120Ft/sq Dynaliner
Custom fiberglass sub boxes
1x 12" L5 Kicker Solobaric 05L5S12
1x Audiobahn A1801T amps
Infinity Reference 6010cs Fronts
Kenwood 4ch KAC-8404
MB Quart DKF113 Rear
0 & 1 gauge wire
IA Speaker Spacers
Misc:
Low/High 6000k HID conversion w/DRL Mod
Fog: 3000k HID conversion
Viper 2-way remote start alarm, Glass sensor, shock sensors, motion, tilt, Turbo timer, etc.
Perrin Radiator Cooling plate
Hawk HPS F&R Pads
DBS 4000 series F&R Slotted and Drilled Rotors
Defi Triple gauge pod
Defi-link Control unit 2
Defi BF white gauges 60mm
-Boost, EGT, Oil Temp, Oil Pressure
Defi White Racer Temp 52mm
AEM UEGO Wideband O2 52mm
Autometer Dual Bezel Gauge Pod
Rally Armor UR Mudflaps
Gentex K30 Autodim/compass/temp/ dual-maplights
JDM STi Spec-C roof vent
Walbro 255lph Fuel pump w/WRX kit
Agency Power Aluminum Pitch Stop Mount
Blizzak WS60 on steelies
2 Hella Supertones horns
2 x BlueSea 6 pair Fused Distribution block with negative bus
1x BlueSea 12 pair Fused Distribution block with negative bus
2x 50amp Bosch Relay
Grimmspeed Air-Oil Separator
HOA 3 Port Boost control solenoid
Optima Yellow Top Battery
Grimmspeed Cowl Brace
Mishimoto Radiator Hoses
Gates Racing Kevlar Timing Belt
Mishimoto Aluminum Radiator
Group-N engine mounts
Carputer:
ZOTAC 880GITX-A-E Mini ITX AM3
2x Crucial Ballistix 2GB DDR3 1333
Seagate Barracuda XT 2TB 7200 SATA 3
Crucial RealSSD C300 2.5" 128GB SATA 3
AMD Phenom II X2 565 3.4GHz OC@3.9ghz AM3
Windows 7 Professional
Lilliput 7"; 629 Touchscreen
TRENDnet TU-400E USB Hub
Rosewill USB 2.0 Wifi Dongle
AZiO BTD603-132 USB Bluetooth
Samsung USB Slimdrive
Auzentech AZT-Forte X-Fi Forte 7.1
AVerTV Hybrid MAX FM/TV USB Adapter
Logitech diNovo Mini bluetooth keyboard/mouse
APEX MW-100 Metal Mini-ITX Case (maybe, tried 4 cases so far)
Opus Solutions 360w DC/DC Converter
DEI HD Radio tuner/ Mitch cable/USB-Serial Converter
Gosget BU-358 USB GPS
Streets and Trips 2010
iNav 2011
2x 25mm fan
1x 30mm fan
1x 90mm fan
1x 120mm fan
2x Linksys 7db wifi antennas
1x Netgear 7db wifi antenna
Roadrunner w/Digital FX 5
Stock Face plate
Win 7
Tripp Lite 375W Dual outlet power inverter hardwired
CCD bullet camera mounted in intercooler scoop
Amplified Headliner TV antenna
License Plate Reverse camera w/IR
2x Bluesea Fused distribution blocks
OBD Link
MJS Gadgets UAS USB Audio Selector
MJS AUdiovox XM Interface
Audiovox XM interface
OBD Link with digital Dash
Old 05-31-2013, 09:54 PM   #260
SIMPFLY
Member#: 54794
Jan 2004 wrx
Nov '15 @ 222K+ Miles
got mine with 5 miles on it almost 10 years, today it has 190k+
10k to 200k still rides like new
SIMPFLY is offline   Reply With Quote
Old 06-01-2013, 04:59 AM   #261
some dude
Member#: 100300
06 WRX
CGM
4am report:
There was a miscommunication, I wanted to know if you were in 4th or 5th gear.
Old 06-01-2013, 05:52 PM   #262
MyOtherRideIsUrMom
Member#: 159636
Totally misread that. Didnt think you were talking about the 200k pic. It was in 4th gear.
Old 06-01-2013, 09:12 PM   #263
some dude
Member#: 100300
06 WRX
CGM
Cool. I was curious. Nice car. Many many mods. That car is pimped out.
Old 06-02-2013, 11:38 AM   #264
coalslaw
Member#: 324808
2006 IWL Stg2
118k miles stage 2 Cobb
brullen tbe cusco 2e coilovers and strut bars
original transmission and clutch.
carputer? damn post pics will you???
coalslaw is online now   Reply With Quote
Old 06-02-2013, 04:44 PM   #265
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
Sooo stock tranny??! How much torque are you putting down??
VinceCarter is offline   Reply With Quote
Old 06-19-2013, 08:23 PM   #266
SnowBRDGod247
Member#: 319756
2002 Audi S4
Just caught up on this.. Sweet 07 man! Very nice numbers hahaha! Makes me feel better w my 18gxt on a 207 w a 6 speed. That cars very nicely modified. I still like my 18g for now but just picked up an LGT for my fiancÚ so in Andrew months I might go up a bit to the Dom 1.5xtr. Thanks for posting... 200k is really impressive w that setup!
Old 06-19-2013, 08:25 PM   #267
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
For some reason, every time this threads gets bumped, I see "mile high club".
Does Subaru have one of those?
Gallo2011 is offline   Reply With Quote
Old 06-19-2013, 08:54 PM   #268
SnowBRDGod247
Member#: 319756
2002 Audi S4
Hahaha yeah in Denver the mile high city
Old 06-19-2013, 09:32 PM   #269
LESSthanDan
Member#: 358897
05' WRX Wagon
I feel lame now for thinking my 05 Wagon had a lot of miles at 91,000.
She runs really well! but mostly stock
Invidia N1 race exhaust
AEM Short Ram
Summer beach Yankee Candle Air Freshener
LESSthanDan is offline   Reply With Quote
Old 06-19-2013, 09:34 PM   #270
OneManArmy
Member#: 36154
2004 WRX Wagon
I'm right there with you. I bought mine brand new with 10 miles on it. It clicked over 225,000 a week ago.
OneManArmy is offline   Reply With Quote
Old 06-19-2013, 09:51 PM   #271
SnowBRDGod247
Member#: 319756
2002 Audi S4
Awesome! What car do you have an 05 as well?
Old 06-19-2013, 10:33 PM   #272
OneManArmy
Member#: 36154
2004 WRX Wagon
2004 WRX Wagon. Been modified in one way or another since I think 3 weeks after I got it. LOL.
Currently...
Looks:
Derailed
JDM fogs
JDM rain guards
STI side skirts
Paint matched everything
Clear bra
Cleared headlights
Full tint
Leather interior
Handles:
Gram Light 57c. Gold.
Pink wagon springs
KYB AGX
Camber bolts
Whiteline steering rack bushing
Whiteline 24 mm adjustable front sway bar
Whiteline 24-27mm adjustable rear sway bar
Whiteline HD rear sway bar mount
Whiteline HD front endlinks
Whiteline HD rear endlinks
Whiteline rear sway bar locks going on soon
Probably pick up a Whiteline ALK as well.
Driveline
Exedy Stage 1 Organic (have a Stg. 2 sitting in my garage)
ACT streetlight flywheel (have another in the garage)
Braided clutch line
factory short shifter
WC Lathe SS heavy shift knob
Kartboy front and rear shifter bushings
Have various bushings that will be going along along with the rear end locks.
More loud
Perrin 3 inch exhaust. Twin tip. The beast mode one.
Port/Polished/Coated Crucial manifold
Injen coated cross pipe
SPT intake
STI up pipe
That's pretty much it for there. LOL. I don't really need much to have fun.
But I do have an 18g XT in the garage and I'm putting together the parts to do an EJ255 long block swap on my stock ECU with an accessport and a tune.
I used to have a gnarly stereo but sold a lot of it off.. but it was...
JL 10w7 in a custom box.
JL 500/1
JL 300/4
6.5" EDT euro frame fronts.
Custom a pillars
Pioneer 700bt (POS)
I sold off the w7 set up. I'll be doing and underseat set up and a new deck.
I've had a few different suspension, wheel and appearance set ups. Used to have even more JDM stuff.
Old 06-24-2013, 10:17 PM   #273
SnowBRDGod247
Member#: 319756
2002 Audi S4
Currently...
Looks:
Derailed
JDM fogs
JDM rain guards
STI side skirts
Clear bra
Cleared headlights
Full tint
Leather interior
Handles:
Pink wagon springs
KYB AGX
Camber bolts
Driveline
Braided clutch line
More loud
SPT intake
STI up pipe
JL 500/1
JL 300/4
Custom a pillars
Pioneer 700bt (POS)
Very nice. I am running the 18gxt as well currently.. Nice turbo you will like it especially if you pair it to the 2.5l but even on my v7 ej207 w Avcs it spools quick and is a lot of fun. I'm eventually going to go up a bit to the 1.5xtr.
Old 06-25-2013, 06:41 PM   #274
OneManArmy
Member#: 36154
2004 WRX Wagon
Nice. That's a great turbo too. I have very minimal goals. I really just want to be right in that 300/300 pocket give or take a few. I'm not a power junky at all. I have plenty of fun with my old tired 2.0. LOL!
Old 06-26-2013, 02:41 PM   #275
some dude
Member#: 100300
06 WRX
CGM
I recently rolled over 160,000 miles. Stock (original) clutch! Original owner and car is all stock.
