Old 09-12-2012, 07:14 PM   #1
bigblueman
Member#: 329135
2003 WRX
Default boost gauge is extremely far off
i just bought a boost gauge off ebay, its GlowShift and was like 45$. installed it and here is the problem. its way off! at idle it will be at about -25 and if i rev it up in idle it will go to about -5. somethings wrong. its mechanical and i hooked it up to the 90 that comes of the BOV. help please?
bigblueman is offline   Reply With Quote
Old 09-12-2012, 07:24 PM   #2
WillW85
Member#: 312151
Did you actually take the car for a drive? Did you get into boost at all? -25 and -5 are vacuum readings, and are what you should expect at idle.
WillW85 is offline   Reply With Quote
Old 09-12-2012, 07:26 PM   #3
bigblueman
Member#: 329135
2003 WRX
i took it for a drive and got 9psi in 3rd gear at 5k rpms. im running stage 2 and should at around 17(my goal?). just driving along maybe at 2.5k im still reading 0 boost.
Old 09-12-2012, 07:34 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What does the gauge read when the engine is off? It should rest at zero, if it does not it's defective.
Old 09-12-2012, 07:38 PM   #5
bigblueman
Member#: 329135
2003 WRX
it reads -1, if you want to be very exact maybe like -1/2.
Old 09-12-2012, 07:55 PM   #6
WillW85
Member#: 312151
My guess would be that your gauge is defective. When I'm cruising at around 2.5k without accelerating, my gauge still reads vacuum. You should only be seeing positive readings on your gauge if you are putting load on the engine.
Old 09-12-2012, 07:57 PM   #7
bigblueman
Member#: 329135
2003 WRX
oh so it should not be reading any boost unless there is a load on the engine? thanks so much, haha still a noob here. ill test it out tomorrow and run it a little harder.
Old 09-12-2012, 08:10 PM   #8
S1CkWrx
Member#: 325249
2012 wrx
dgm
drive it and where you normally boost see what it says
S1CkWrx is offline   Reply With Quote
Old 09-13-2012, 08:19 PM   #9
02x2wrx
Member#: 328986
My gauge reads -19/20 For vacuum at idle, At about 3200 Ish it engages and at WOT at 5.5 Ish Reads 18psi.
02x2wrx is offline   Reply With Quote
Old 09-13-2012, 09:51 PM   #10
hoffmanEstates
Member#: 122043
04 wagonier
psm
I have -20* at idle
hoffmanEstates is offline   Reply With Quote
Old 09-14-2012, 07:59 PM   #11
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
You mentioned it's mechanical- make sure you didn't crimp the hose coming through the firewall.
mechatricity is offline   Reply With Quote
Old 09-16-2012, 09:05 PM   #12
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
check the hose for kinks as stated.
if you run wide open throttle from 2k rpm in 2nd or 3rd you should see a reading close to your max/target boost level.
I think mine hits about 12-13psi (bone stock except for the gauge)
aerosaaber is offline   Reply With Quote
