Old 09-05-2002, 11:23 PM   #1
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
Default need help please with boost
ok i posted this before but iam trying again, i just got my greddy profec b and at he shop it was running good but then it stop at 8psi now it won go past it, i had to go to work so i wasnt able to leave it...i rested the ecu bay disconnecting the battery butstill nothing, the nobs dnt work slightly,
also now iam noticing some rattling at 1500rpms not at idle around the turbo area, could this be something loose or a cracked piston, i still have power but no more than 8 psi, so what can be the problem
MAXXPSI is offline   Reply With Quote
Old 09-06-2002, 12:45 AM   #2
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Could be a lot of things
8 psi - seems like your stuck on the factory wastegate spring
Without being able to see / hear your car it would be very hard to guess whats wrong
- How does the car feel at idel and low gas before you reach 8 psi ???
I'd say go to a mechinic who knows turbos to see whats up
alfriedesq is offline   Reply With Quote
Old 09-06-2002, 07:58 AM   #3
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
ok thanks hope nothing s broken
Old 09-06-2002, 09:19 AM   #4
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Check all the hoses to and from the Greddy solenoid, the wastegate and the Profec B head unit. Also check to make sure the unit is getting power properly.
atf78 is online now   Reply With Quote
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
boost ? need help please... 20rex02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-22-2009 06:18 PM
need help please with ohlins adjustables JDMV7STISPECC Brakes, Steering & Suspension 12 08-19-2008 10:01 AM
Help please with Greddy PRofec B-spec 2 boost controller Slow06WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-23-2006 06:34 PM
Boost Problems NEED Help! Please! RIP_2my_GC8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-28-2004 10:14 PM
