#1 |
Member#: 268088
SCIC
Vehicle:2011 WRX Sedan OBP |
Anyone experience grinding going into third on a 2011 WRX? Especially noticeable on cold mornings so I was thinking might be related to the clutch howling issue I know others have experienced...Planning on taking it into the dealer for some more terrible service, but wanted to see if anyone else has experienced the same issue?
#2 |
Big Ron
Moderator Member#: 18062
#3 | |
Member#: 268088
SCIC
#4 |
Member#: 253541
Vehicle:2011 WRX 5DR Premium OBP |
If it's under warranty, why not ask SOA or the dealer?
#5 |
Member#: 268088
SCIC
I intend to... Wanted to see if anyone else experienced the same thing... In other words, if this is a common issue or unique to my car...
#6 |
Member#: 280943
Vehicle:'11 WRX |
Mine does it, occasionally. It's not frequent or violent enough for me to do anything about it.
Interested to see if it's an issue or just another 5MT quirk... |
#7 |
Member#: 253541
I think you're just trying to shift too fast while being careless. I've done it once, I recognized that I was sloppy on that shift though.
#8 |
Member#: 329252
Vehicle:2012 Subaru WRX |
My problem is with 2nd gear.
I freaking hate 2nd gear on this car. Can't get it smooth hardly ever. |
#9 |
Member#: 312122
Vehicle:2000 Forester L White |
I talked to my mechanic and he was saying that unless it's a rough shift every single time (or very frequently) then it's not an issue with the tranny but with the hydraulics in the clutch, after I started double clutching into 3rd (i'm the one with the post about the 04) it shifts perfect meaning it's some leaking hydraulic seals....i think
#10 | |
Member#: 268088
SCIC
#11 | |
Member#: 268088
SCIC
#12 |
Member#: 275888
Vehicle:2011 WRX Limited SWP |
If it's only slightly crunchy, just change out your trans oil to Andrewtech or Uncle Scotty's cocktail, bam, problem solved. I had a slight crunch into third on cold mornings and Andrewtech's coctail fixed it like a champ.
#13 |
Member#: 300268
i have this similar issue. when im on 2nd gear at 3k RPM, and slow down when the RPM goes down, i hear grinding sound. i hear this around 2.5k - 2k RPM. I started to notice on 3rd gear too, but most i hear from the 2nd gear when RPM goes down from 3k to 2k RPM.
i did have chance to take it to the dealer yet, but im going to soon. let me know if anyone have this issue too.. |
#14 | |
Member#: 268088
SCIC
#15 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
#16 |
Member#: 275888
#17 |
Member#: 268088
SCIC
Does the tranny fluid need to be changed at 20k miles? If not, they're paying for it, if so, then I'll pay
#18 |
Member#: 159474
AKIC
Vehicle:2013 BRZ Ltd 6MT CBS Counter-steer like a boss |
![]() ![]() ![]() ![]() Problem: ![]() ![]() ![]() ![]() Long story short: Since Day 1 my 3rd gear shifts were always kind of notchy and rubbed a bit. Sometimes the shifter would pop out and I'd "grind", but I always assumed that I was just shifting wrong. I asked around NASIOC and the dealership and was assured that it was just a WRX quirk. This having been my 3rd turbocharged Subaru, but 1st WRX, I continued to drive it like I normally would. At 20k miles I had the fluid changed to Extra-S. At 29k miles my 4th gear started popping out, too. I scheduled to get the fluid changed and a week before the appointment at 34.5k miles the shift fork broke. There's a lot of debate about this, but here are the facts: - With my new shift fork my car now shifts better than it ever did from the day I drove it off the lot - After driving kyletakahero's 2012 WRX and _davin's 2011 WRX I can tell you that any kind of rubbing, grinding, notch or clip of shifting is NOT normal. Something IS wrong. - Since I've posted about my issue I've received about 15 different messages from either local or non-local parties that are having similar issues with either their 3rd gear or even 2nd gear not being smooth. Theory: I believe that the shift forks are coming misaligned from the factory, but offset ever so slightly so that only a few cars are affected every several thousand or so. That's the best anyone's been able to guess, so far. Steps to Remedy: Call SoA at 1-800-SUBARU3, #4, #4 and set up a Warranty Claim yourself. Have a specific, trusted dealership in mind. If your car is modified, as in tuned, then prepare for an uphill battle. Warning: Some people on here WILL hate and say that you suck at driving and that there's nothing wrong with these cars. Don't waste your time defending yourself. They're not worth the hassle. Let them live in their tiny worlds. You'll be busy enough dealing with reality. Advice: Be prepared to pay for the repair out-of-pocket first. My repair cost me $1500 since a transmission teardown is Mitchell-rated at a flat $1k. If you have friends or can do the transmission teardown yourself then I advise you get it done. I'll subscribe to this thread to check in on your progress. I will let you know that since I've had the car back I've purposely driven it hard to test it out and have not had a single missed shift or anything. Before, even when the car was new, sometimes I'd just drive normally to work and the shifter wouldn't settle in ALL the way, would pop out, and I'd grind. It killed my driving confidence slowly over the past 2 years that I've owned the car. I wish I had money to throw at it sooner, but I didn't. Thanks for making this thread. |
#19 | |
Member#: 268088
SCIC
#20 |
Member#: 159474
AKIC
Hey, no problem! Since your car is stock I doubt you'll have to pay, but just BE PREPARED. The timing of shift fork failure was convenient in that I had just acquired enough money to cover the bill initially. Any time before that I never had $1500 to my name to have it diagnosed and repaired out of my own pocket.
I will let you know that the replacement shift fork is not a regularly stocked item. My mechanic had to order it from a Subaru dealer on the east coast after spending roughly 4 hours calling around locally and from coast to coast in the Lower 48. He had it shipped UPS Red, so that's probably why my bill was about $100 more than it needed to be. Let us know when you've set up a Warranty Claim with Subaru. If you have options of which dealership you're going to have look at, but don't have one in mind, ask others in your local forum which one has the least hatred for turbocharged Boxer motors. |
#21 |
Member#: 163058
Vehicle:2011 Impreza WRX SWP Hatchback |
Neither can I. I'm going to chalk it up to being a newb at driving stick but my shifts from 2nd to 3rd, 3rd to 4th and 4th to 5th are perfectly fine and smooth. I just...don't understand.
#22 |
Member#: 268088
SCIC
I'll definitely post an update once I've made a warranty claim and taken the car in... I've already had several bad encounters with the dealer but I think it's a good idea to start with SOA first.
#23 |
Member#: 303086
Vehicle:2008 Subaru WRX Dark Grey |
don't know if you guys are new to AWD platforms, but there is a lot more drivetrain shock/movement to deliver power to all four wheels. the combo of transmount bushings/shifter bushings front-rear/ group n trans mount should get rid of a lot of the sloppy/clunky feel you are experiencing (cheap mods, only downside is a tad more noise in the cabin), obviously the OPs got a different issue...but the sloppy second gear feeling can be fixed easy
#24 |
Member#: 159474
AKIC
Thanks for bringing that to light, Ian. My car has Kartboy front and rear shifter bushings and a Group N transmission mount. I've never had an issue with 2nd gear.
#25 |
Member#: 226331
South East
Vehicle:2012 WRX Hatch Papa Smurf |
Mine feels like it rubs or scratches during the 2nd to 3rd shift sometimes. Does it at least once every time I drive the car. It used to not do it at all. No audible noises from the shift, just the 'grab ass' feeling from the shifter.
I've noticed that if I short shift at like 2,500 RPM, it is much, much more likely to do it. I push the clutch in all the way during shifts, but it doesn't really seem to matter. Doesn't do it in neutral; only does it when the car is under load. Every thread I could find on this problem blamed the driver. Every. Single. One. Just from what I have seen with my car, the build quality on the 3G's is sub-par compared to the older Subarus. So far I have racked up: -Car refusing to go into 4th gear, 90 miles (got better and better during break-in, doesn't do it anymore) -Fluctuating temperature gauge, 500 miles (still does it, been in the shop 3 times) -Wacky turn signal, 1500 miles (fixed it myself) -Dead water pump, 2100 miles (replaced at dealership) -Noisy TOB in the morning, 3000 miles (still does it) -Starter interrupt switch on clutch pedal stuck, car wouldn't start, 3500 miles (unstuck the switch myself so I could go to work, dealership couldn't replicate, hasn't happened again) -Center console lid wouldn't stay shut, 5500 miles (fixed it myself) Car is bone stock and currently has ~7300 miles. Can't wait to see what happens next. |
