Old 09-13-2012, 08:30 PM   #1
SubWrx13
Member#: 330568
05 Wrx
Default Cobb AccessPort vs Dyno ProTune
Hey guys,
I just bought an 02 wrx with several mods such as :
AEM cold air
Hks turboback 3" full exhaust
Hks bov (yes I know its not good for a wrx)
Bigger intercooler
Aluminum radiator
Now I would like to assume the guy who spent the money to drop the mods also had the brains for a protune but I just dont know. I already need a new tranny 2 weeks later so im assuming not...
Anyways as the question will prove im a noob at tuning. Especially turbo cars.
My question is do I spend $300+ on a protune at the dyno track which is 90 miles away, or do I buy an accessport for $200 more and get maps online or from someone who knows what they are doing? It basically a single time tune vs the ability to tune any second of any drive I want. Right?
SubWrx13 is offline   Reply With Quote
Old 09-13-2012, 09:07 PM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Get an Accessport.
Download the maps you need.
Download Cobb's map editor software.
If you don't like the car off the accessport online maps learn to use the Cobb software or get a dyno tune.
(best of all possible worlds.. unless you learn to tune yourself. Then you wasted money on the cobb setup instead of just getting a a tactrix or similar)
ProfessWRX is offline   Reply With Quote
Old 09-13-2012, 09:07 PM   #3
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Dyno tuning will result in higher horsepower and better driveability.
Black94Snake is offline   Reply With Quote
Old 09-13-2012, 10:29 PM   #4
SubWrx13
Member#: 330568
05 Wrx
Thanks so far.
One to one!
does anybody else want to chime in with their opinion? Break the tie maybe add some more detail as why one may ne better than the other?
Full disclosure to help I do NOT know how to operate cobb software.
Old 09-14-2012, 12:00 AM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Cars get tuned for mods. The Cobb tunes are very broad and safe... There is no discussion, there is no opinion. If you want the most power out of your mods, get a dyno tune. If you want to be like every other chucklehead out there that says "I'm running Cobb Stage X" then go for it, just know that you will not be taking full advantage of the parts you are paying for.
Old 09-14-2012, 02:29 AM   #6
SubWrx13
Member#: 330568
05 Wrx
I thought that the cobb allows you to essentially dyno it anywhere anytime.. Based on ecu readings, etc. Plus you would then have access to clear codes and check settings on the go.
Whereas if you get a protune its always going to run in one setting you cant change and you also wont have the ability to read codes etc.
Also, if I got accessport couldnt I set several dyno maps and even get several protunes down the road I can interchange depending on driving conditions?
I feel like there are a lot of pros and cons to each. Or I just dont understand what the cobb accessport really is.
Old 09-14-2012, 05:45 AM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Yea, you really don't have a clue.
I never said NOT to buy an accessport. I just said that a dyno tune will provide better results.
Old 09-14-2012, 06:00 AM   #8
SubWrx13
Member#: 330568
05 Wrx
Nope but ill openly admit it and I am very open to learning. I saw the cobb accessport for the first time ever yesterday and read up on their site a bit. But I must not understand something. Thats why I asked and clearly addressed im a noob to ecu hoping someone with the knowledge would take a min to try and explain the real differences
Old 09-14-2012, 07:50 AM   #9
quazimoto
Member#: 70395
By the way,the term "Protune" is a custom tune done with Cobb's professional Protuner software. It's splitting hairs but maybe use the term "custom tune".
http://www.cobbtuning.com/Domestic-P...rs-s/70754.htm
quazimoto is offline   Reply With Quote
Old 09-14-2012, 06:15 PM   #10
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I think you would do well to read this:
http://forums.nasioc.com/forums/show....php?t=2339845
Old 09-15-2012, 12:32 AM   #11
SubWrx13
Member#: 330568
05 Wrx
Great article!
Old 09-23-2012, 05:41 PM   #12
Dka67
Member#: 296721
11 5door
^this
A good tuner can give u a few maps to keep on your Accessport to play with.
Dka67 is offline   Reply With Quote
