Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 09-14-2012, 03:29 AM   #1
Swagon_Wagon
Member#: 294424
2006 Spec B. #41
specb silver
Default Do you bead roll the end of your ic pipes?
cant think of the name right now but what do you use guys use to roll the ends of your pipes so your clamps have something to hold onto the pipe.
check this slick custom tool out. may have to go this way.
Swagon_Wagon is offline   Reply With Quote
Old 09-14-2012, 03:33 AM   #2
houdni
Member#: 146044
bead roll?
houdni is offline   Reply With Quote
Old 09-14-2012, 07:39 AM   #3
bmw325ix
Member#: 204652
its a good idea to, i dont have a tool to do it so my car doesn't have them. Was running 20lbs with no issue. Also all comes down to how good of a fit the pipes are.
bmw325ix is offline   Reply With Quote
Old 09-14-2012, 12:01 PM   #4
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
That second one reminds me of the cowboy rail clamps that we use at work
olsen726 is offline   Reply With Quote
Old 09-14-2012, 12:04 PM   #5
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Harbor freight sells bead rollers with rollers thatg would accommodate your needs
dirtslayer is offline   Reply With Quote
Old 09-14-2012, 03:24 PM   #6
Swagon_Wagon
Member#: 294424
2006 Spec B. #41
specb silver
Thanks. I just go the budget route with the vice grips. I was just seeing if you guys did it any other cheap ways or even Did it at all.
Old 09-14-2012, 04:02 PM   #7
dirtslayer
Member#: 242550
olive drab
I like the vise grips idea. DIY innovation at its finest
Old 09-14-2012, 11:28 PM   #8
Heater Guy
Member#: 215239
"Beadform" is the only way to go. We have used them for 25+ years. They are slick!
www.beadform.com
Heater Guy is offline   Reply With Quote
Old 09-14-2012, 11:55 PM   #9
Swagon_Wagon
Member#: 294424
2006 Spec B. #41
specb silver
yea but im not rich, i can afford 20 vice grip tool that does what i need. not like i build custom ic piping for 200 people a year.
Old 09-15-2012, 03:26 AM   #10
NJJer
Member#: 288369
2011 STI Limited
I use these at work.
Earl's EZ-Beader
http://www.holley.com/types/Earl’s%20EZ-Beader.asp
NJJer is offline   Reply With Quote
Old 09-17-2012, 01:52 PM   #11
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i like this cheap and simple tool that Mechie3 made
PARANOID56 is online now   Reply With Quote
Old 11-13-2012, 01:12 PM   #12
3mlwhly
Member#: 217648
01 2.5rs
this is really great... u would need a machine shop to make the dies though right... plus looks limited on size, but other than that great ingenuity
3mlwhly is offline   Reply With Quote
Old 11-13-2012, 03:11 PM   #13
Extreme Turbo Systems
Member#: 194655
08 STI
We bead roll everything. It keeps those couplers tight at high boost levels. Using something similar to this:
Check out our Holiday Sale Pricing! 15% off!
Extreme Turbo Systems is offline   Reply With Quote
Old 11-14-2012, 12:17 PM   #14
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
I weld beads around the outside of the pipe. Not as clean and not quite as effective, but it's better than nothing. More for stopping the pipe sliding out of the coupler than sealing though.
DeleriousZ is offline   Reply With Quote
Old 11-14-2012, 09:12 PM   #15
bugeye1257
Member#: 188598
yes definitely helps!
bugeye1257 is offline   Reply With Quote
Old 11-15-2012, 03:12 AM   #16
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
I've looked at these... Earl's ez beaders.
http://www.jegs.com/p/Earls/Earls-EZ...40092/10002/-1
expensive if you have many different sizes but if you only need one size it wouldn't be terrible... Cheaper then getting a roller like above, but not modified visegrips cheap...
video of use on gearz... kinda neat.
Zefy is online now   Reply With Quote
Old 11-24-2012, 01:11 AM   #17
T U R B U L N T
Member#: 160634
2oo6 STI
CGm with a beard.
this defiantely helps big time.. first kit i had didnt have this.. a couple times i had it blow off right at the throttle body... what a back fire. lol yea i thought my car blew up a couple times.. but needless to say next kit had this and not one issue... ive seen some high psi cars (non subarus... like turbo big blocks) they have this and also make metal brackets bolting the 2 meeting points of pipeing together to ensure they never ever come off or apart....
T U R B U L N T is offline   Reply With Quote
Old 11-24-2012, 03:15 AM   #18
Swagon_Wagon
Member#: 294424
2006 Spec B. #41
specb silver
THis^ weld hooks on the pipe so you can run a high tension spring from pipe to pipe, kinda like how some snowmobile heads work. that is you happen to need to run over 40 psi, which we all do right, 35 psi is stock on the wrx's ?
Old 11-26-2012, 07:51 PM   #19
kay95
Member#: 45494
95 impreza L awd
green
I try to bead everything but the tight radius pipe coming from the turbo to the fender was hard to get the bead roller I borrowed. I just used a alittle hair spray on that one and now I cant really get it off.
kay95 is offline   Reply With Quote
Old 12-16-2012, 07:57 PM   #20
bmw325ix
Member#: 204652
I finally got my hands on the Vibrant manual bead roller. lts a little pricey for just one project but hopefully Ill get more jobs to use it on.
Old 12-21-2012, 12:35 AM   #21
da_kernel
Member#: 325324
2010 STI Wagon
+1 for welding beads around pipe. Works great and hoses won't pop off. Welder is easier to get a hold of than a bead roller.
da_kernel is offline   Reply With Quote
Old 12-22-2012, 11:54 AM   #22
CEdwards89
Member#: 311341
My boost pipes have always been rolled. I have known a few people that would blow a boost pipe mid cruise and would have to wait for them to get it back together. You dont wanna be that guy.
CEdwards89 is offline   Reply With Quote
Old 10-01-2013, 04:03 AM   #23
Tarmac RS
Member#: 1020
Kinda funny how this pic turned up here. Thats my pic, from my garage, rolling a bead for my Audi UrQuattro. Anyway, it works for me on the larger piping. I was actually shopping for smaller beading tools when I stumbled on my pic in google images.
Tarmac RS is offline   Reply With Quote
Old 10-22-2013, 03:09 PM   #24
T-WRX13
Member#: 352665
I use the Vibrant aluminum weld on fittings, they are amazing and no more blowing off intercooler pipes!
T-WRX13 is offline   Reply With Quote
Old 10-23-2013, 01:42 PM   #25
omiotek
Member#: 272090
personally i think all intercooler pipes should be bead rolled and proper clamps used as well. if they arent bead rolled they are properly made..... intake pipes you can get away with no bead rolling but i do it anyways for asthetics.
omiotek is offline   Reply With Quote
