Old 09-14-2012, 01:30 PM   #1
Stangy
Member#: 329676
1999 GC8 R-STI
Default My new r-sti is killing me!!
Hey all. I'm new to Subaru but have an extensive background in vw's as I have been building/racing them for years. I have searched and researched these CEL's for a few days now but can seem to figure this out.
I have a 99rs with v2 sti engine..its throwing 3 CEL's. See below.
#32: 02 sensor (I'm only running one up front in the header) this one seema easy. Will a run of the mill 1994-95 impreza square 3 prong 02 sensor work?
#42: Idle switch (what the heck is that?)is this just my tps? Are they not integrated?
#43: Throttle switch (no clue) I don't even think my car has that switch. Assuming its the switch at the pedal. I have also heard this is a dummy code
Where would I find the throttle switch and idle switch.
Any help is great!
Stangy is offline   Reply With Quote
Old 09-14-2012, 02:28 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
What kind of code reader are you using? I was expecting 4 digit codes. Is this a pre OBDII ECU?
Old 09-14-2012, 03:02 PM   #3
Stangy
Member#: 329676
1999 GC8 R-STI
I am using the two green connectors under the dash. Once connected they will flash cel codes. Pre obd2 I would assume since is a pre 95
Old 09-14-2012, 03:05 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes a normal usdm 93-95 or so impreza oxygen sensor fits. You might have to move the harness or extend the wires a bit depending on how your harness was done.
Idle and throttle switch are the TPS. It should be the same as the early 91-94 turbo legacy.
Old 09-14-2012, 03:15 PM   #5
AgentJ17
Member#: 306411
1995 STi RA
very eg33 such braap
Use a 91-94 NON-turbo legacy as the wiring harness is long enough. Still the same o2 sensor. The turbo legacy sensor's wiring harness is too short.
AgentJ17 is offline   Reply With Quote
Old 09-14-2012, 03:27 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
On the JDM WRX, there is a little switch on the throttle pedal. That is what code 43 is referring to. The code doesn't affect how it runs and only shows up as a code in memory, not as an immediate code (i.e. will not set the CEL unless you read the stored codes). No one seems to know what the switch is for. It is ok to ignore it.
Idle switch is inside the TPS. Below are the trouble shooting steps. Most likely your TPS is just out of adjustment. Try step #3 first.
rob is offline   Reply With Quote
Old 09-14-2012, 04:33 PM   #7
Stangy
Member#: 329676
1999 GC8 R-STI
beauty thanks!
The TPS is shot- figured this out a few min ago.
Ordered a 1994 impreza 02 sensor and a 1994 legacy tps.
Thanks all!
