Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 09-14-2012, 04:44 PM   #1
Member#: 280543
The thermometer that reads outside ambient temp is not reading accurately, this has happened on 2 occasions like today it is 93 degrees out but the in thermometer reads a steady 82 degrees O.o found this dead thread that didn't get resolved
Any help would be greatly appreciated.
Edit: if anyone can also direct me to where the sensor is on an 09 wrx I would also greatly appreciate it. Thanks
Subiezilla is offline   Reply With Quote
Old 09-16-2012, 12:58 AM   #2
Member#: 161541
2003 WRX
Maybe Im wrong but this is a thermistor. If its not a wiring problem isolate the sensor and check its resistance with a DMM (disconnected from the circuit) at given temps with a heat gun (not directly on it) Check the FSM for specs. Also you have to take inconsideration that its not going to be even close to 100% correct due to radiant heat and wind. GL
globalrex is offline   Reply With Quote
